timeout on meteonews causes ALL after to die **solved**
lrosenman
Post by lrosenman »
on both 4.9za and 4.9zb, I was seeing a timeout on the meteonet process reporting to meteonews.
When I run it with -d, I shows the timeout, and then "Alarm Clock" and then process exit.
Can this be changed to log the error, and continue on?
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Re: timeout on meteonews causes ALL after to die
"-d" is a one time invocation. When running in daemon mode it should not stop.
Do you have evidence that is stops operation in daemon mode? You can check with "rcmeteonet status"
lrosenman
Post by lrosenman »
Yes. I got whines from CWOP, WeatherBug, et al that they were NOT receiving data.
When I ran it without -d, I got a "Alarm Clock" not, and process exit.
I ran it with -d to figure out what was happening.
Please look at your timeout handling for meteonews.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
and:
root@raspberrypi:~# rcmeteonet status
-bash: rcmeteonet: command not found
root@raspberrypi:~# ls /etc/init.d/
README kbd nfs-common single
bacula-fd keymap.sh ntp skeleton
bootlogs killprocs procps ssh
bootmisc.sh kmod rc thttpd
checkfs.sh loggerd rc.local udev
checkroot-bootclean.sh meteonetd rcS udev-mtab
checkroot.sh motd reboot umountfs
cron mountall-bootclean.sh rmnologin umountnfs.sh
dbus mountall.sh rpcbind umountroot
ddclient mountdevsubfs.sh rsync urandom
exim4 mountkernfs.sh rsyncd watchdog
gpm mountnfs-bootclean.sh rsyslog wd_keepalive
halt mountnfs.sh samba wear
hostname.sh mtab.sh screen-cleanup x11-common
hwclock.sh networking sendsigs
root@raspberrypi:~#
so, where is this rcmeteonet command.
BTW, this error was on the 5 minute CRON invocation of meteonet.
root@raspberrypi:~# crontab -l | grep meteonet
*/5 * * * * sleep 120; /home/meteohub/meteonet
root@raspberrypi:~#
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
the rapid-fire daemon WAS sending data.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman wrote:Yes. I got whines from CWOP, WeatherBug, et al that they were NOT receiving data.
That is neither an evidence nor does a timeout there aborts anything from a code perspective.
Please check with "rcmeteonetd status" if process is still there or check "ps ax" output
for a process called "meteonet". If the process really drops, then please give me access to your
rig on port 22 so I can check what goes on.
lrosenman
Post by lrosenman »
As I said, the -r daemon is fine.
the cron one was dieing on the meteonews timeout.
I disabled meteonews, and cwop, et al started getting data again.
How can I get you ip/creds/etc to look at my box?
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
root@raspberrypi:~# ps ax|grep meteonet
2488 ? S 24:07 /home/meteohub/meteonet -r
12300 ? Ss 0:00 /bin/sh -c sleep 120; /home/meteohub/meteonet
12559 pts/0 S+ 0:00 grep meteonet
root@raspberrypi:~#
root@raspberrypi:~# rcmeteonetd status
Usage: /etc/init.d/meteonetd {start|stop|reload|restart|force-reload}
root@raspberrypi:~#
I *AM* an experienced Linux/Unix/etc sysadmin.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
and as I said, the rapidfire *WAS* working.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
look at the findu.com history for EW3654 (my station) from Friday to Sunday. You will see **NO** data until I removed Meteonews.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman wrote:I *AM* an experienced Linux/Unix/etc sysadmin.
Will you grant me access or do you think you can fix it yourself?
lrosenman
Post by lrosenman »
I will grant you access, but want to pass credentials, and ip/port privately.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
PM with creds sent.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
I installed an updated version on your rig that better handles the overall timeout.
Will also be part of the next general update.
lrosenman
Re: timeout on meteonews causes ALL after to die **solved**
Post by lrosenman »
Thank You.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
