3G/4G, WISP, AP MR-3020 Switch and connect ??'s
mixmaven
Post by mixmaven »
Ok, 2 very simple questions.
1. Does it matter where the 3G/4G/WISP/AP switch is set? I am reading ahead because I have the router ordered and it should be delivered in the next day or so.
2. I have the Davis 6555 IP data logger and VP2. Do I plug the datalogger into MR-3020 and configure Meteobridge to connect via wireless -or- can I leave my setup as it is today an just plug the MR-3020 into my network LAN and configure Meteobridge to connect to the VP2 console via IP? Wireless is dodgy where I want the console and I would prefer to have everything wired if possible.
-mix
Re: 3G/4G, WISP, AP MR-3020 Switch and connect ??'s
mixmaven wrote:1. Does it matter where the 3G/4G/WISP/AP switch is set? I am reading ahead because I have the router ordered and it should be delivered in the next day or so.
The switch has no meaning with Meteobridge
mixmaven wrote:2. I have the Davis 6555 IP data logger and VP2. Do I plug the datalogger into MR-3020 and configure Meteobridge to connect via wireless -or- can I leave my setup as it is today an just plug the MR-3020 into my network LAN and configure Meteobridge to connect to the VP2 console via IP? Wireless is dodgy where I want the console and I would prefer to have everything wired if possible.
No changes needed to your WLIP setup. Just add the Meteobridge to your LAN and you are fine.
mixmaven
Post by mixmaven »
Thank you kind sir.
I have email confirmation the router arrived, I will be setting it up this evening. Hoping for rapidfire and to get my soil sensors back online on WU.
