Problems after 5.0 update
Jippe
Post by Jippe »
I don't have system log anymore, it shows blank? Other logs works fine.
ftp upload fails often, connection timed out. (on desktop with filezilla and nautilus theres no problem.)
Re: Problems after 5.0 update
My updated systems do not show any of the problems you mention. Does not look like an update issue to me.
lrosenman
Post by lrosenman »
I am seeing more timeouts on WeatherNetworks and others with 5.0 than I did with 4.9[z,za,zb,zc].
Also, with the number of graph creations I had at the 1 minute mark, I would get a lot of failures for my MHtags.
I calmed the number of creations at the 1 minute mark down, and it seems better, but I'm still seeing more timeouts for the weather networks.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
I can set timeout to a larger amount with next update.
BTW, how does the message that tells you about a timeout look like?
lrosenman
Post by lrosenman »
date: Sat, 30 Aug 2014 07:17:45 -0500
INBOX 288|from: meteohub@raspberrypi.lerctr.org
FN 15|to: ler@lerctr.org
SENT 13|subject: Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
SPAM 12|
bacula 9|FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
clamav-rules 134|
commits 13|
Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
emulation 8|1586 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
fs 6|1587 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
hackers 21|1588 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
java 11|1589 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
mobile 0|1590 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
net 24|1591 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: mv /var/run/meteohub/MHtags11.html /var/run/meteohub/uploads/MHtags.php
ports 112|1592 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
ports-announce 0|1593 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
ports-bug 297(10)|1594 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
security 0|1595 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
stable 118(12)|1596 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
usb 9|1597 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
virtualization 11|1598 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
x11 15(1)|1599 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
lopsa-us-tx-aust 0|1600 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
mailman-announce 0|1601 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
mailman-user 35(4)|1602 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
openssl-user 36(3)|1603 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
advocacy 0|1604 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
announce 1|1605 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
bugs 22(2)|1606 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
committers 19|1607 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
docs 6|1608 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: mv /var/run/meteohub/MHtags11.html /var/run/meteohub/uploads/MHtags.php
general 52(1)|1609 + Aug 30 meteohub@raspbe (0.7K) METAR/KTXHUTTO9
hackers 412(7)|1610 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
jdbc 2|1611 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
jobs 1|1612 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
novice 5(1)|1613 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
odbc 2|1614 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
sql 0|1615 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
www 3|1616 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
announce 0|1617 + Aug 30 meteohub@raspbe (0.8K) Meteohub (raspberrypi): FTP Upload failed: cp /var/run/meteohub/MHtags11.html /data/myweb/uploads/MHtags.php
-*-Mutt: =#ARCHIVE/2014/08/meteohub [Msgs:1676 1.2M]---(date/date)----------------------------------------------------------------------------------------------------------(96%)---
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
Meteohub (raspberrypi): Cannot connect to Weather Network "weather underground rapid fire"
From meteohub@raspberrypi.lerctr.orgAdd contact Date Tue 11:48
no response from weather underground
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Looks like you changed things in the system. I don't see these problems with a stock Meteohub system.
I think it is obvious that I do not give support on non-stock Meteohub systems.
lrosenman
Post by lrosenman »
what do you mean? I have only ADDED stuff via your interface.
What is wrong?
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
xcom
Post by xcom »
I am still on 4.9z and have the time outs. It's not an update issue. It's an issue with wundeground.
lrosenman
Post by lrosenman »
and the MHtags stuff was (I think) due to having too much stuff on 1 minute updates).
It would be nice if you would be a little more forthcoming with why you think I modified something......
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Jippe
Post by Jippe »
admin wrote:My updated systems do not show any of the problems you mention. Does not look like an update issue to me.
Ok, it just happent after update.
Any idea how to get system log back and how to deal with connection time outs?
Cheers,
Jussi
Apart from individual connection problems reported by user "lrosenman" there is no issue. Newest hot-fix for version 5.0 does give a bit more time out period, but if you are on rapid fire to WU, you cannot wait a long time before dropping the connection.
Also putting tons of upload services to 1 minute intervals is not a too great idea, when you experience upload timeout problems. This is something every user has to work out individually and when it is ones hobby to push everything to the limit, then the upcoming issues are the bonus for doing so ;-)
What exactly is the problem with your log files? Is just "system log" impacted? Please give a bit more detail. Did you do changes to the Meteohub system via ssh shell? Did you install additional services?
Jippe
Post by Jippe »
Now, after newest update, system log came back.
Only mod via ssh was starting rsync service few months earlier.
I have rapid fire to WU activated, maybe I'll try disabling it.
Jussi
