VantagePro2-AirBridge-WeatherUnderground Won't Communicat
bpriestly
Post by bpriestly »
I have tried various ways to set up the Airbridge so it will communicate with WeatherUnderground, but receive errors and no real time weather is being sent to Airbridge. Under the tab Select Station, I selected the Davis VantagePro2 button, but I am not sure what I fill in for IP address? IP address for router, does the VantagePro2 have its own IP address, or some other IP address format? Metobridge and Ambient Weather (where I pruchased Weather Station and Airbridge) do not have technical support?
Re: VantagePro2-AirBridge-WeatherUnderground Won't Communica
bpriestly wrote:I have tried various ways to set up the Airbridge so it will communicate with WeatherUnderground, but receive errors and no real time weather is being sent to Airbridge. Under the tab Select Station, I selected the Davis VantagePro2 button, but I am not sure what I fill in for IP address? IP address for router, does the VantagePro2 have its own IP address, or some other IP address format? Metobridge and Ambient Weather (where I pruchased Weather Station and Airbridge) do not have technical support?
If you have the product: http://www.ambientweather.com/airbridge.html
you are not selecting the Davis station but the Meteostick, that tall thing next to the white box on the foreground.
So you are reading the Davis weather station by using the stick and not the console. Scroll down on the list, select Meteostick ,the appropriate frequency for Europe or US and try again,
Succes, Wim
P.S. This is the on-line manual, did you read it?
http://site.ambientweatherstore.com/Man ... bridge.pdf
bpriestly wrote:Under the tab Select Station, I selected the Davis VantagePro2 button, but I am not sure what I fill in for IP address?
When you are using the Meteostick with Meteobridge (this bundle is named Airbridge by Ambient) your have to select "Meteostick" as weather data receiver.
bpriestly wrote:Metobridge and Ambient Weather (where I pruchased Weather Station and Airbridge) do not have technical support?
We have, but this really does not look like a "technical" problem at all ;-)
Please invest some minutes reading instructions from ambient or if you need more please start reading "www.meteobridge.com".
