Air-cam won't recover on its own after power loss **solved**
steviebaby59
Post by steviebaby59 »
Ever since the upgrade of AirCams with latest firmware 3.0.7, I am having an issue. Whenever my meteobridge takes a power hit, (which is happening a lot with the storms we are having) I have to manually initialize my Aircam by selecting Save on the Select Station tab. If I don't do this every time, my Air-cam won't work. It always recovered before without having to do this.
steviebaby59
Re: Air-cam won't recover on it's own after power is lost
I reset my unit back to version 2.2. It's working fine now.
tones
Post by tones »
I also have aircam with firmware 3.0.7 and whether with meteobridge 2.2 or 2.3 firmware I get
Initialization of AirCam successfully done
Error: AirCam Web Interface set to HTTPS. Meteobridge cannot handle that, please set back to HTTP
tones
Post by tones »
Update:
Updated to 2.3 again and camera initiliased and accessed.
steviebaby59
I updated to version 2.3 on last reboot. Same results. Air-Cam would not initialize until I manually forced it.
There is a problem with DIR-505 hardware on this. Do you have a DIR-505?
steviebaby59
I'm using the TP-LINK TL-MR3020 platform.
Should be fixed with just released update for MR3020, MR3040, WR703N. DIR-505 is still in the works.
steviebaby59
I updated and rebooted. Air-cam still would not come back until I forced it. Don't know what else I can do on my end.
jmontamat
Post by jmontamat »
I updated and rebooted MR3020, aircam v1.2 working properly
New version uploaded. Please reboot. Should work now on all platforms.
steviebaby59
I did update and reboot. It seems to be working fine now. THANKS! :D
