Aircam will not reinitialize after reboot. ***Solved***
baobab
Post by baobab »
I have the reboot script set to automatically reboot my MB once every 24 hours. After the reboot the connected Aircam fails to initialize. Aircam fw is 1.2. I need to manually reinitialize it to get it to work again. Any thoughts?
Re: Aircam will not reinitialize after reboot
What hardware are you on? DIR-505?
baobab
Post by baobab »
TL-MR3020
steviebaby59
Post by steviebaby59 »
I'm having the same issue. I went back to version 2.2. It works on that.
jmontamat
Post by jmontamat »
The same happens when there is a loss of feeding fw 1.2
Just release update should solve problem for MR3020, MR3040, WR703 completely.
DIR-505 will need additional work.
Please give it a try and report back.
New version uploaded. Please reboot. Should work now on all platforms.
baobab
Re: Aircam will not reinitialize after reboot. ***Solved***
Post by baobab »
It appears to be working now. Thank you.
