If I run Weather Display on my PC what exactly will work with Meteohub?
Will I see live data?
Will Weather Display use the historic data from Meteohub?
If the above works how do I setup Weather Display to work with Meteohub and is there a setup guide?
Brett.
Meteohub and Weather Display Software
Re:Meteohub and Weather Display Software
Yes.oliverb wrote:Will I see live data?
After you have set it up for Meteohub each time WD starts it commences by pulling in data collected by Meteohub since the time that WD recalls as when it last ran.Will Weather Display use the historic data from Meteohub?
By setting the 'Data Logger' pick up time (probably wrong terminology, I'm not on my WD computer) you can adjust how far back WD looks.
No formal guide. A search on the Weather-Watch forum might help, but essentially it is a matter of setting a Station Type of "Stationless", and then providing the IP and port of your Meteohub in the TCP/IP section of the COM Port setup. Both Station Type and COM Port are set in the WD Control Panel.If the above works how do I setup Weather Display to work with Meteohub and is there a setup guide?
I hope that helps.
In answering a question on Weather-Watch,com I've given an outline of how to set up WD for Meteohub based on my current understanding.oliverb wrote:...how do I setup Weather Display to work with Meteohub and is there a setup guide?
That answer can be found at:
http://www.weather-watch.com/smf/index. ... #msg260588
Maybe it will be useful to others too?
