Solar in a jar for "dummys"
idociko
Post by idociko »
As simple as effective. Working in just 10 minutes!
Check my website: http://www.hazajon.eu/weer/solar_in_a_jar.php for discription.
Jos
HeinrichH
Re: Solar in a jar for "dummys"
Post by HeinrichH »
Good idea Jos, I'm going to try this. Where can I find the solar calculator you used on your site?
Henk
idociko
Post by idociko »
Henk,
You can find the solar calculator here: http://www.stella-maris.org.uk/maxsolar.php.
On my webpages you just had to click on the-calculator screendump.
When you worked this out give us your web-url, would be nice.
Good luck,
Jos
WS Grave
Post by WS Grave »
Hi Jos, what a coincidence to find you with a solution for solar in a jar :)
I always used that when I was working with WD, but with Meteohub there was no solution until now.
Bought me a jar and put a sensor in it.
It's already on my site, but watching it carefully for better finetuning.
I'm curious how and if it works :)
See my website.
Billy
Post by Billy »
Hi Jos,
really interesting. :D
For putting the right sensor in the jar it would be helpful to know which is the max. temperature in the jar.
In addition it might be helpful to see a picture of your "additional JAR sensor".
Thanks in advance
Billy
idociko
Post by idociko »
I don't know yet what the maximum tempreture will be in summer. My Jar is running since 2 month now. I think tempreture can in summer go up to >60º
I don't have a picture availeble. It is an Oregon THGR810 in an empty (0,6 ltr.) pickle jar with the lit downside.
Billy
Post by Billy »
@Jos
Thanks for your quick response this might help.
Billy
HeinrichH
Post by HeinrichH »
idociko wrote:As simple as effective. Working in just 10 minutes!
Jos
Jos, it's working, the only problem I have that sometimes the values are negative, any idea how to limit the value to zero??
Henk
idociko
Post by idociko »
I make use of the negative value's. At night when Wqm is negative the sky is clear, when Wqm is positive the sky is cloudy.
