WMR88
This is intended for WMR100, WMR200, WMRS200 and RMS300 specific topics
wilmastop
WMR88
Post by wilmastop »
I do not have a blank field for sensor definition on sensor page.
Mister Pasternak logs in my Meteohub 3D3 ALX3W and find that: the data coming in via USB show lots of read/init errors.
The weather station WMR88 is defined on meteohub log page, but I have no white stroke on sensor page under the weather station notifacation.
So I can not give the sensors an ID.
The Oregon software and a virtual Weather station does see the sensors.
The WMR 88 was disconnected for a few days because of transport, after good working.
Please help.
sensor page
sensor page
weather station page
weather station_ 24-05-2012.JPG (84.71 KiB) Viewed 21356 times
log file for WMR88
log file for WMR88
meteohub log.JPG (135.77 KiB) Viewed 21356 times
YJB
Re: WMR88
Post by YJB »
Can you post some screenshots as the description of your problem is not very clear to me.
Ysbrand
wilmastop
Re: WMR88
Post by wilmastop »
Thank Ysbrand,
Screenshots ara posted.
I hope that they clear the problem.
krgds
YJB
Re: WMR88
Post by YJB »
It appears to me that you are still having communications problems between MH and the weather station. Sometimes the dmesg log will reveal additional information.
Other than that the 1st thing I would recommend is to update Meteohub to the current version. Beyond that you can try a different USB cable, reboot/reset your WMR.
Ysbrand
wilmastop
Re: WMR88
Post by wilmastop »
I have the Meteohub updated to: 4.9i, connected a new USB cable, reboot Meteohub and WMR88.
Still have no white stroke on the sensor page, in the weather station field, to give the sensors a ID.
I Go away for an few days and let everything on, maybe after that few days there is a white stroke.
Is it possible to make a factory reset for the Meteohub, so I can get clear software on Meteohub?
krgs
Re: WMR88
there is no factory reset button, but you can setup the CF card from scratch with the USB installer stick. Please read here: http://wiki.meteohub.de/Setup_ALIX.1D
Activation code will remain the same (please copy it into a save location as you will need to enter it again).
wilmastop
Re: WMR88
Post by wilmastop »
Hello Admin,
Do you have any other suggestions?
Please I still have no blank stroke for sensor ID.
krgs
JuTs
Re: WMR88
Post by JuTs »
Hi Wilmastop
Did you find a solution ? I have the same problem. I managed to add the WMR88 from the "Weather Station" menu. But after that I can't add the sensors, there nothing in the trigger listbox.
With the the Oregon software all is working correctly
wochips
Re: WMR88
Post by wochips »
I had the same problem but just left everything running for about 4 hours and the sensors started to appear. Seem that they need a bit of time to be recognised.
WMR88 UV
iConnect
