Update 4.9u
What's hot...
Re: Update 4.9u
The cyclic update allows me to deliver hot-fixes without incrementing version number, just ignore that.
Records with bad hum data are not stored, but reported in the log file only.
el-rain
Re: Update 4.9u
Post by el-rain »
How is it with the data on Port 5500 are they transparent or are Loop packets with values out of range dropped here as well.
As I take a short look here while I had the alerts and the value for the outside humidity (Byte33) looking OK, but need to check in more detail to be 100% sure.
el-rain
Re: Update 4.9u
Post by el-rain »
Just short update,
Error stopped after some hours and didn't comeback till I stopped logging today, when I enabled logging again got error to read enovy internal logger (see other thread) and got back the error.
Bad th0(0) sensor data, "humidity" (110) out of range [0:100]
lets see if this stop as well after some hours.
andybalt
Re: Update 4.9u
Post by andybalt »
After updating to 4.9u, I made a clone of my iConnect USB stick but am unable to come up on the clone due to a licensing failure.
Here is the message:
Demo version expired after more than 3 months of data has been recorded.
Demo Version has timed out. You need an activation code for further operation (System-ID: KWIxxDQ).
The activation code field contains the correct code but my system ID *not* the ID that shows in the message. Why doesn't my system ID transfer to the cloned USB stick? Is this a bug or do I need to do something to either correct the system ID or get a new code?
I'm back up on the old stick for now but it has some data errors and I'd like to replace it.
Thanks!
Re: Update 4.9u
It needs an activation code transfer. Can be done here:
http://wiki.meteohub.de/Transfer
Diet
Re: Update 4.9u
Post by Diet »
Thanks for implementing no-ip.com - but unfortunately it doesn't update my dynamic IP address.
Seems as if there is an issue with perl on my meteohub.
My config file looks like this:
# generated by meteohub
pid=/var/run/ddclient.pid
protocol=noip
use=web
web=checkip.dyndns.org
server=dynupdate.no-ip.com
login=<mylogin>
password='<mypassword>
<subdomain>.no-ip.org
If I'm trying to start ddclient manually with debug options (ddclient -daemon=0 -debug -verbose -noquiet 2 /etc/ddclient.conf) I'm getting the following error:
=== cache ====
DEBUG: proxy =
DEBUG: url = checkip.dyndns.org
DEBUG: server = checkip.dyndns.org
CONNECT: checkip.dyndns.org
Can't locate IO/Select.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl .) at /usr/lib/perl/5.8/IO/Socket.pm line 116.
meteohub version:
Linux Kernel: 2.6.21.7 266 BogoMIPS, 30 MB RAM, NSLU2 (266 MHz)
MeteoHub: 4.9u (Build 1278) ©2013 by smartbedded UG (haftungsbeschränkt)
Thanks, Diet
