ERROR: AcuRite 1035 Bad thb0(0) sensor data **solved**
digiital
Post by digiital »
I have been getting this error for a little while now. Anyway to fix it? It was working at one point, but I needed to reset my station and ever since I have been getting this error and it hasn't been reporting the pressure.
logger (26.01.2014 01:44:33): Bad thb0(0) sensor data, "pressure x10" (17774) out of range [4000:12000]
logger (26.01.2014 01:44:38): Bad thb0(0) sensor data, "pressure x10" (17774) out of range [4000:12000]
logger (26.01.2014 01:44:48): Bad thb0(0) sensor data, "pressure x10" (17774) out of range [4000:12000]
logger (26.01.2014 01:44:54): Bad thb0(0) sensor data, "pressure x10" (17774) out of range [4000:12000]
digiital
Re: ERROR: AcuRite 1035 Bad thb0(0) sensor data, "pressure x
Post by digiital »
Anyone?
digiital
Post by digiital »
No support for this issue?
I don't have a solution for this. It remains unclear to me, why such unreasonable values are reported.
Does the console show correct pressure values?
digiital
Post by digiital »
I believe so, but will check for the next day or so every 6 hrs or so to compare the stations readings and current pressure at the local airport.
Will report back,.
Kanok
Post by Kanok »
Hi Digital,
Is the reading on the console still looks ok? or both are off limit. If both are off limit, you might open a case with Acurite for pressure sensor malfunction.
Kanok
Ambient Weather WS-1900
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
http://kanok.net/pws
Looks like I could drill down on the root cause. Fix is uploaded and should be effective after a reboot.
Indoor temp and pressure is affected by the fix.
dicklee
Re: ERROR: AcuRite 1035 Bad thb0(0) sensor data **solved**
Post by dicklee »
Barometric pressure is not reporting to CWOP. My weather station an Acurite model 01525 5n1 and I am using Meteobridge v 2.4
I keep receiving the same error message. Can you tell me how the erro was solved. I have been working on this problem for several weeks.
Thank you very much. George Lilly (North Deering Weather) :( :( :(
What does live data tab tell about pressure?
Did you enter correct altitude on system tab?
Did you apply a pressure correction offset on westher station tab?
dicklee
Post by dicklee »
Live data does not show presure sensor
Altitude is correct
There is no tab on the Acurite 01525. It has a 14 day calibration mode (called 14 day learning mode.) I have reset the
station three times to to repeat the calibration but the barometric sensor is still not correct. I understood the meteobridge has it's own sensor. :?: :?:
Thank you for your help.
The learning feature for calibration of the pressure sensor of the accurite is a feature critized by many,
as results are often not that great. However, Meteobridge reads pure sensor data and correction
has to be done manually on the "weather station" tab of the Meteobridge.
Does message window on "System" tab show any issues regarding pressure?
tinso
Post by tinso »
I'm having this same issue after moving my console to another room. The AcuRite console reads the pressure correctly, but on the meteobridge system tab give me the error: logger (21.08.2015 11:20:31): Bad thb0(0) sensor data, "pressure x10" (12174) out of range [4000:12000]
On the Live Data tab I don't have the outside pressure sensor displaying. I'm using the latest version 2.5
How were you able to fix this issue?
