Meteobridge reporting phantom Sensors **solved**
joey
Post by joey »
I'm running the Ambient Weather version of MeteoBridge, "Linux/OpenWrt 3.3.8 mips (BE), FW 1.2, MeteoBridge 2.1 (3148)", and the device is reporting UV data to Awekas. I don't have a UV sensor. I haven't found anyway to disable that sensor in the UI or customize what is being sent to Awekas. Does anyone have any ideas on how to fix this?
Joey
Re: Meteobridge reporting phantom Sensors
what station do you have?
joey
Post by joey »
Davis Vantage Pro 2 Wireless. That communicates to the Weather Envoy and the datalogger is plugged into that.
That is strange, as the Vantage reports 0xff when no UV or solar sensor present and these values are suppressed for submission. Are you sure that the UV and solar sensor plugs are not connected on your PCB in your ISS? If water pours into that this also might generate false readings.
joey
Post by joey »
admin wrote:That is strange, as the Vantage reports 0xff when no UV or solar sensor present and these values are suppressed for submission. Are you sure that the UV and solar sensor plugs are not connected on your PCB in your ISS? If water pours into that this also might generate false readings.
Yes. It doesn't report this way when using the WLINKIP dongle to Weatherlink. It's only something that started with the meteobridge. That said, it (meteobridge) is always reporting a constant "16" to awekas.
UV 1 h 16.0uvindex 16.0uvindex
UV index -- 16.0uvi 16.0uvi 16.0uvi 16.0uvi 16.0uvi 16.0uvi 16.0uvi 16.0uvi
joey
Post by joey »
joey wrote:
admin wrote:If water pours into that this also might generate false readings.
The temp hasn't gotten over -17c in a week so I think we can discount water. :-)
Hi, can you please mail the MAC of your Meteobridge (as displayed on system tab) to "info(at)meteobridge.com"?
alunj
Post by alunj »
I have the same issue with a VP2 . Maybe its water , gonna check !
alunj
Post by alunj »
yup loads of water , dead iss board :( full of salty nasty green water since we had 180 kph winds !
