WMR200 no data **solved**
dazza1033
Post by dazza1033 »
I have just set up a WMR200 with a dlink505.
I am getting the following status
logger (14.02.2014 18:45:01): connect station 0 (WMR-200 via USB HID).
logger (14.02.2014 18:45:01): unexpected 0 bytes delivered from weather station 0 (WMR-200)
logger (14.02.2014 18:45:01): disconnect station 0 (WMR-200): response without data
Does the dlink505 work with the wmr200? I have tried a couple of USB hubs (powered U] and un powered) but I don't seem to be able to get a connection
Thanks in advance
Darren
Re: WMR200 no data
yes it works with the WMR-200. Please provide a screen dump of your "weather station" tab.
dazza1033
Re: WMR200 no data
Post by dazza1033 »
dazza1033
Re: WMR200 no data
Post by dazza1033 »
well it worked briefly until the dlink rebooted (power failure)
The unexpected zero bytes error is back.
Re: WMR200 no data
Do you have the mandatory USB 2.0 hub inbetween?
dazza1033
Re: WMR200 no data
Post by dazza1033 »
Yes, I have tried a powered and un-powered hub.
Re: WMR200 no data
Can you please send MAC of your Meteobridge (displayed on "system" tab) to "info(at)meteobridge.com" ?
Re: WMR200 no data
Further investigation showed that a driver for USB HID connected weather stations was missing on platform DIR-505. Bug is fixed now, all it needs is a reboot of the DIR-505 to load fixed code.
dazza1033
Re: WMR200 no data **solved**
Post by dazza1033 »
All good, thanks for your help!
cmccartney
Post by cmccartney »
I am having almost exactly the same problem, except with a WMR100 and TPLink TL-MR3020. Is it possible that there is a more generic fix for the USB?
usb problem is related only to DIR-505 platform. TL-MR3020 works fine, there must be another problem in your setup, not to be discussed in this thread.
cmccartney
OK, I will gather some data and start a new thread.
Thanks for the quick reply.
