Version 2.3 problems (Wind WMR200) **solved**
lorenz1982
Post by lorenz1982 »
I have problems with my meteobridge on an MR3020 and station Oregon Scientific WMR200.
When I update to version 2.3 I have problems with the wind sensor. Unfortunately I have to go back to version 2.2 :( :( :( .
Wind 1.png (34.29 KiB) Viewed 6020 times
MeteoBorgo: www.meteoborgo.it
Re: Version 2.3 problems (Wind WMR200)
I doubt that version 2.2 works, while 2.3 does not.
In order to log wind speed beside wind sensor data also data from primary temp outdoor sensor must be there, as this is needed for windchill calculation. When your WMR200 has reception problems with wind sensor and/or primary outdoor temp sensor, Meteobridge will behave as lined out in your screen dumps.
I am quite sure, that this is your problem, not version 2.3.
lorenz1982
The temperature outside has no problems and is displayed correctly. I tried a bit 'of times is always the same. With version 2.3 I have this problem. With version 2.2 it works correctly. Now I'm back to version 2.2.
I really would like to go into this. could you please send your MAC to "info(at)meteobridge.com" and reset password to default "meteobridge" to allow me a login?
lorenz1982
admin wrote:I really would like to go into this. could you please send your MAC to "info(at)meteobridge.com" and reset password to default "meteobridge" to allow me a login?
I have just sent you the MAC address. Thanks.
Vertikar
Post by Vertikar »
Can confirm I've also got the same issue with the same hardware. Have gone back to 2.2 and getting wind data ok.
lorenz1982
Now with the latest update everything is working.
Vertikar
Post by Vertikar »
Looks good for me too, thanks for the update.
