Is it possible to get the Meteobridge with a Meteostick to see an add on Leaf /Soil station? It sees the ISS just fine, but I cannot get it to see the Leaf Soil station. On the Select Station page I have Meteostick: Vantage chosen. I see the drop down for "more Davis Sensors". I choose "Leaf / Soil Station" and press the Save button, but it does not stay.
Any idea how to get it to work?
Meteostick with Davis Leaf Soil station **solved**
Re: Meteostick with Davis Leaf Soil station
You also have to select the correct transmitter ID for the Leaf/Soil Station. It does work fine with mine.
Can you please share a screen dump of this with us?
Here is a screenshot. The ISS is transmitter 1, and the Meteobridge sees it. There is no way that I can see to set the Leaf / Soil to transmitter 2. The drop down box is greyed out. When I click save, the Leaf / Soil just disappears. If I set the Vantage option to transmitter 2 nothing is found.
I am think of switching from my Meteohub to a Meteobridge and the Meteostick works fine with the Meteohub. There it can see both the ISS and Leaf / Soil without issue.
- Meteobridge Station Select screen
- MeteoBridge-Station.JPG (98.06 KiB) Viewed 3723 times
It has to look like this:
But the latest Meteobridge version had a bug that dimmed the selection of transmitter ID for additional sensors.
I just fixed that, so please reboot your Meteobridge and make appropriate transmitter ID settings.
Thanks for spotting this bug.
Excellent! Works great now. Thanks a lot!
