Problems with soil moisture readings **solved**
Re: Problems with soil moisture readings
Just released 5.0d. Please give it a try in regard to reporting soil/leaf data to WU.
- Senior Boarder
Wow, that was a quick update, thanks! The Weather Networks page on the Meteohub device now shows list boxes for the additional (soil/leaf) sensors, just waiting for WU to update...admin wrote:Just released 5.0d. Please give it a try in regard to reporting soil/leaf data to WU.
{pause}
OK, it's showing readings, but I think a subtle flaw may have crept into the way the data is being uploaded:
This is for raw sensor data:Soil Moisture: 23.0
Soil Temp: 2.0 °C
Leaf Wetness: 0.0
soil 1 1:10 12s -69db 20.1°C 23cbar
soil 2 1:11 9s -75db 0.0°C 20cbar
leaf 1 1:15 1s -69db 20.1°C 0wet
Yes, there is a factor-10 bug for leaf and soil temperatures. Will be fixed shortly.
I made a new 5.0d version that should have it fixed. Please install and give it a try.
- Senior Boarder
Works fine now, thanks!admin wrote:I made a new 5.0d version that should have it fixed. Please install and give it a try.
