RPi B+ won't connect to WMR-100
markhiseman
Post by markhiseman »
Hello, I hope someone can help me.
I've been running my RPi B+ with my WMR-100 reliably for a few weeks now. Today I added a UV sensor on the Sensors page and pressed 'save and restart data logging'. Since then, the RPi has refused to connect to the WMR-100. On the Sensors page it says 'error connect socket 127.0.0.1:5555 :Connection refused'
I tried hot and cold rebooting both the RPi and the WMR-100 several times, and unplugged/replugged/replaced the USB cable, but always the same result. I tried deleting and re-adding the Weather station in Meteohub. I also tried a WMR-88 station, but still no connection so I think the problem is at the Meteohub/RPi end.
Can anyone suggest how to fix my problem?
Thank you,
Mark.
rune
Re: RPi B+ won't connect to WMR-100
Post by rune »
I'm having same issue with an WMR100 on a VirtualBox, and haven't been able to solve it yet. When WMR is connected, can you then reboot or shutdown Meteohub without problems?
markhiseman
Yes, when the WMR-100 is plugged in to the RPi via its USB lead, I can reboot/shut down Meteohub. But Meteohub will not connect to it.
rune
Post by rune »
ok, I cannot reboot/shutdown when WMR is connected. Meteohub can connect to WMR at system-start, but e.g. restarting datalogging breaks the connection and then I cannot shutdown/reboot any more.
