Weatherstation Lufft WS600 **solved**
The_Weatherman
Post by The_Weatherman »
i am going to connect a lufft weatherstation to meteohub. I take a look in the manual but there is no further information about how to connect or how to choose the parameters. For me its interesting to know what baudrate and what kind of protocol i have to select.
Best regards
The Weatherman
Re: Weatherstation Lufft WS600
Lufft was connected via UMB and a serial connection.
Serial connection is 19.200 baud, 8 bit, no parity.
The_Weatherman
Ok, thanks. What kind of UMB protocol is used? The UMB binary (binär) or UMB ASCII?
when I remember correctly the ASCII one.
The_Weatherman
So i have tried to connect the station but there occurres an error. I have added the screenshots in the attachments.
In Meteohub i have not found the settings of the baudrate.
Setting of the sensors
Settings of the Weatherstation
What does "Log Files" say? Section "meteohub log" should show reports form the data logger.
It is always a good idea to inspect log files, when something doesn't work... :lol:
The_Weatherman
The following Information is available in the meteohub protocol:
2015.03.26 13:49:10 log file cleared by user
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
logger (01.01.1970 01:00:22): System date not properly set. Please set date and time correctly before data logging can start.
wmr928fulleval(26.03.2015 13:50:59): recomputation of weather data started.
wmr928fulleval(26.03.2015 13:51:00): recomputation of weather data finished: 0 records processed in 0 seconds ( records per second)
logger (26.03.2015 13:51:18): data logger (version 5.0f, build 69) started.
logger (26.03.2015 13:51:19): connect station 0 (WS600 via USB serial).
But on the top of every page there is a warning that no sensor is connected “Warnung: Der Wetterstation ist noch kein Sensor auf der Seite "Sensoren" zugewiesen”.
So I tried to create a new virtual sensor (I don`t know if this is required) and now these information is available in the meteohub protocol:
logger (26.03.2015 13:56:39): parent process received termination signal (15).
logger (26.03.2015 13:56:39): child process received termination signal (15).
logger (26.03.2015 13:56:39): disconnect station 0 (WS600): wrap-up
logger (26.03.2015 13:56:40): data logger stopped.
logger (26.03.2015 13:56:41): Demo license timed out. Please contact "info@meteohub.de" to get a valid license.
The information that the demo licence has timed out make no sense for me because on the System Info page is the information given that the demo version works for the next 280 days. “Eingeschräkte Demoversion, noch 280 Tage gültig”
The_Weatherman
Now i have rebootet the system (rpi) and then disconnected the weatherstation while the meteohub system was running again and connected after about a few minutes (look at the logfiles below). On the the serial device at the weatherstation i can see a status LED which is blinking shortly when a command is coming in. There is only a blinking when the meteohub connects to the station (bold marked text below). There is no poll command by the meteohob between that time.
2015.03.26 13:58:32 log file cleared by user
wmr928fulleval(26.03.2015 14:00:29): recomputation of weather data started.
wmr928fulleval(26.03.2015 14:00:30): recomputation of weather data finished: 0 records processed in 1 seconds (0 records per second)
logger (26.03.2015 14:00:48): data logger (version 5.0f, build 69) started.
logger (26.03.2015 14:00:50): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:01:20): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:01:50): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:02:20): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:02:50): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:03:20): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:03:50): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:04:20): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:04:50): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:05:20): station 0 (WS600), can't open device /dev/ttyMH112: No such file or directory
logger (26.03.2015 14:05:50): connect station 0 (WS600 via USB serial).
logger (26.03.2015 14:06:20): child process received timeout signal (14).
logger (26.03.2015 14:06:20): disconnect station 0 (WS600): exit
logger (26.03.2015 14:06:21): data logger stopped.
logger (26.03.2015 14:06:21): data logger (version 5.0f, build 69) started.
logger (26.03.2015 14:06:22): connect station 0 (WS600 via USB serial).
logger (26.03.2015 14:11:52): child process received timeout signal (14).
logger (26.03.2015 14:11:53): disconnect station 0 (WS600): exit
logger (26.03.2015 14:11:53): data logger stopped.
logger (26.03.2015 14:11:53): data logger (version 5.0f, build 69) started.
logger (26.03.2015 14:11:55): connect station 0 (WS600 via USB serial).
logger (26.03.2015 14:17:25): child process received timeout signal (14).
logger (26.03.2015 14:17:25): disconnect station 0 (WS600): exit
logger (26.03.2015 14:17:26): data logger stopped.
logger (26.03.2015 14:17:26): data logger (version 5.0f, build 69) started.
logger (26.03.2015 14:17:27): connect station 0 (WS600 via USB serial).
logger (26.03.2015 14:22:57): child process received timeout signal (14).
logger (26.03.2015 14:22:57): disconnect station 0 (WS600): exit
logger (26.03.2015 14:22:58): data logger stopped.
logger (26.03.2015 14:22:58): data logger (version 5.0f, build 69) started.
logger (26.03.2015 14:22:59): connect station 0 (WS600 via USB serial).
To what ID is your UMB configured? These systems are not plug and play.
Did you connect it for testing and configuration with your PC? Does it work there?
admin wrote:when I remember correctly the ASCII one.
Looking at the code I think that it is the binary format... sorry.
The_Weatherman
Thank you the protocol was the only problem!
My Lufft weatherstation has a built-in pyranometer that measures the global radiation (Globalstrahlung) and has the channel number 900. Is it possible to read out this parameter by myself (via virtual sensor or something like that)?
can you please send specs how to extract that data to "info(at)meteohub.de".
At the moment only these sensors are supported
{7, 100, 0}, // act temp celsius
{7, 110, 0}, // act dew celsius
{7, 200, 0}, // rel hum %
{7, 300, 0}, // act press hpa
{7, 305, 0}, // act sealevel press hpa
{7, 460, 0}, // average wind speed m/s
{7, 400, 0}, // act wind speed m/s
{7, 500, 0}, // wind direction degrees
{7, 700, 0}, // data (precipitation flag: 0 none, 60 ran, 70 snow)
{7, 600, 0}, // rain total mm
{7, 800, 0}, // rain rate mm/h
I added the solar radiation sensor. Which type of Meteohub hardware do you have?
The_Weatherman
I use a rasperry pi b+. Do you still need the specs to continue?
nope, just install update 5.0i again (I added some code for your station).
