code 4 Cf card crashed
citi
Post by citi »
My card seems to have problem with the code : "failed (code 4)".
When I read the cf card with an explorer I have a lot of files.
Where I could find all my data and my MeteoHub setup ? How to repair ?
thank you
Alix1d, Vantage Pro2
Re: code 4 Cf card crashed
Please connect a keyboard and let operation go on via "cntrl D"
citi
Post by citi »
Yes, it is working with ctrl D but how I could fix this problem ?
Please login to secure shell (as offered in the screen dump) and do a manual "fsck" run (also as recommended in the screen dump).
citi
Post by citi »
ok, I think I am going to re install with a new card (the cf card have 4 years and 350 round).
I make a backup of the config and the data. So with that I will find all my Meteohub like before ?
Thank you.
Please be aware that you will need to generate a new activation code
as explained here: http://wiki.meteohub.de/Transfer
Therefore, you should save the current credentials before removing the old CF card.
citi
Post by citi »
"Therefore, you should save the current credentials before removing the old CF card."
What do you mean save the current credentials ? I don't understand.
Thank you
citi
Post by citi »
I don't understand how to save the credentials ?
Thank you
citi wrote:I don't understand how to save the credentials ?
Thank you
Maybe you should read the link first?http://wiki.meteohub.de/Transfer
What is needed is specified there:
This tool asks for System-ID and activation code of your old x86/SheevaPlug Meteohub installation.
You will find System-IDs on the "System Information" page of your Meteohub
and activation code on "Maintenance" page.
So you have to copy / print those long numbers from your browser first.
Because later on you need those numbers to transfer your licence to the new system.
