WDL and Davis VP Forecast
Discussion, issues, recommendations around Meteohub's dashboard and WD Live integration
G3ZSS
Post by G3ZSS »
I notice that WDL does not display the Forecast from my Davis VP. It worked OK when I had WD feeding WDL. Is the Forecast in WDL generated by WD, or does it come directly from the VP Console?
Thanks Peter
wfpost
Re:WDL and Davis VP Forecast
Post by wfpost »
It does work with my VP2 and meteohub and WDL6.01 (worked with 5.03 and 5.04 also)
You could try using the WDL clientraw parser, Boris mentioned:
http://www.tnetweather.com/wd-parser.php
and search for this line >>
015 Forecast Icon I 19 (Partly Cloudy)
G3ZSS
Post by G3ZSS »
My Forecast icon appears to be working. However using the Parser, I notice that in clientrawextra.txt line 531 "Weather Display (or Davis) Forecast" is blank. Does this text come from Weather Display, or can it be read from the Davis VP?
Peter
wfpost
Post by wfpost »
Upps, I was confusing Forecast Icon with forecast text. Sorry!
Then line 049 is the one to look at >> In my case
049 Weather Desc L Increasing clouds with little temperature change. Precipitation possible within 24 to
Do you use 2.6g?
There was a problem with earlier 2.6 version. Also when starting with WDL and meteohub my Forecast text did not show up after I changed the language tag to German. Dunno if it is still a problem.
<language>german</language>
