Problem with memory - Solved
xcaleb
Post by xcaleb »
The sheevaplug write to log, that memory is full. Due to I checked the saved data, and I see, that in last time data are so big (see picture)
In 07/2014 I added meteostick and davis uv, solar.
In 08/2014 I added 4x temp, 4x soil, 1 leaf.
In 10/2014 I canceled wmr200 sensors (tem, hum, wind, uv) and I replaced sensors with david sensors (no additional sensor, replace part by part).
Weather in Czech Republic, Central Bohemia (GPS: 50.067773,13.640127)
http://pocasi.chytry.info/
xcaleb
Re: Problem with memory
Post by xcaleb »
Problem 2:
I deleted old data (before I backed it to the pc). Than I used the recompute, but after 21 hours the still compute data (see picture)
And in uploaded the charts is a lot of errors
xcaleb
Post by xcaleb »
Last question, is it possible to use the SD card 16 GB?
YJB
Post by YJB »
You observations are correct:
- More sensors will generate more data
- While the recomputaion is runnning, the graphs won't be correct, as they relay on aggregate data (that is generated during the recomputation)
- Yes, recompute will take a long time on a Sheeva. More data, implies longer runtimes
- Yes, you can increase the size of the /data directory, but I'm not sure if it is a good idea, as it will imply that your Sheeva will need to manage even more data.
xcaleb
Post by xcaleb »
Thank you YJB for your answers.
Btw, can you advise me other solution for saving and computing bigger of data volume? (meteoplug?)
YJB
Post by YJB »
I can't give you a recommendation; I'm using MeteoHub on a virtual machine (Data since 2009), but obviously it doesn't make sense to run a VM if you do not already have something else running 24*7.
ON1DQD
Post by ON1DQD »
xcaleb wrote:Last question, is it possible to use the SD card 16 GB?
Yes it's possible.
I have use GParted Live to change the system and data partition sizes (make a backup in case something goes wrong).
