Hi Boris,
I have found a bug and is present in software update released on November 7, 2015 and released November 9, 2015 . As to him by a restart in turn goes to the first start-up right at the second time opdate will see this message:
wnetd (10/11/2015 08:42:23): process started.
logger (10/11/2015 08:42:26): Historical data loaded (19 records).
logger (10/11/2015 08:42:26): data logger (5.0L version, build 7564) started.
logger (10/11/2015 08:42:28) station 0 (Vantage), can not open device / dev / ttyMH: No such file or directory
logger (10/11/2015 08:42:58) station 0 (Vantage), can not open device / dev / ttyMH: No such file or directory
logger (10/11/2015 08:43:28) station 0 (Vantage), can not open device / dev / ttyMH: No such file or directory
The meteo bridge can not read me date logger.
Will want to solve this problem?
Thank my thanks.
I also have a probeem discovered select Internet Log: Allow login from the Internet using this URL displays this message: Service Unavailable
The server is tempo- unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache / 2.4.7 (Ubuntu) Server at admin.meteobridge.com Port 443
Thank you for solving these bugs.
Bug in the Meteobridge TP-LINK TL-MR3020 (plus USB hub) Data
MeteoOudkarspel
- Senior Boarder
Last edited by MeteoOudkarspel on Tue Nov 10, 2015 7:24 pm, edited 1 time in total.
Sincerely,
Re: Bug in the Meteobridge TP-LINK TL-MR3020 (plus USB hub)
Dear
i have same problem, station doesn't work and also tunneling.
I tried all and the resolution is the return of version 2.5. In tab System and Maintenance in the menu choose stick to version 2.5.
I hope that is only a temporary bug
MeteoOudkarspel,
The "The server is tempo- unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache / 2.4.7 (Ubuntu) Server at admin.meteobridge.com Port 443" error you mentioned is being discussed in the recent forum below:
Cannot Connect to Meteobridge Remote Access - viewtopic.php?f=56&t=10580
MeteoOudkarspel
- Senior Boarder
Thanks Boris,
The problem I have described this item is in release of Version 2,6
released November 13, 2015 resolved completely.
My gratitude is very large.
Sincerely,
I have the same problem, started acting up day before yesterday. A reboot in each of the last 2 days got data to push to Wunderground. Today however it will not restore the push. Tried going back to previous software versions but that didn't fix it. Any suggestions?MeteoOudkarspel wrote:Thanks Boris,
logger (17.02.2016 13:25:14): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
Thank you!
Are you using the mandatory USB hub?
