Bug in the Meteobridge TP-LINK TL-MR3020 (plus USB hub) Data
MeteoOudkarspel
Post by MeteoOudkarspel »
Hi Boris,
I have found a bug and is present in software update released on November 7, 2015 and released November 9, 2015 . As to him by a restart in turn goes to the first start-up right at the second time opdate will see this message:
wnetd (10/11/2015 08:42:23): process started.
logger (10/11/2015 08:42:26): Historical data loaded (19 records).
logger (10/11/2015 08:42:26): data logger (5.0L version, build 7564) started.
logger (10/11/2015 08:42:28) station 0 (Vantage), can not open device / dev / ttyMH: No such file or directory
logger (10/11/2015 08:42:58) station 0 (Vantage), can not open device / dev / ttyMH: No such file or directory
logger (10/11/2015 08:43:28) station 0 (Vantage), can not open device / dev / ttyMH: No such file or directory
The meteo bridge can not read me date logger.
Will want to solve this problem?
Thank my thanks.
I also have a probeem discovered select Internet Log: Allow login from the Internet using this URL displays this message: Service Unavailable
The server is tempo- unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache / 2.4.7 (Ubuntu) Server at admin.meteobridge.com Port 443
Thank you for solving these bugs.
Last edited by MeteoOudkarspel on Tue Nov 10, 2015 7:24 pm, edited 1 time in total.
Sincerely,
Fred
Re: Bug in the Meteobridge TP-LINK TL-MR3020 (plus USB hub)
Post by Fred »
Dear
i have same problem, station doesn't work and also tunneling.
I tried all and the resolution is the return of version 2.5. In tab System and Maintenance in the menu choose stick to version 2.5.
I hope that is only a temporary bug
crazyace
Post by crazyace »
MeteoOudkarspel,
The "The server is tempo- unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache / 2.4.7 (Ubuntu) Server at admin.meteobridge.com Port 443" error you mentioned is being discussed in the recent forum below:
Cannot Connect to Meteobridge Remote Access - viewtopic.php?f=56&t=10580
MeteoOudkarspel
Thanks Boris,
The problem I have described this item is in release of Version 2,6
released November 13, 2015 resolved completely.
My gratitude is very large.
Sincerely,
mburt
Post by mburt »
MeteoOudkarspel wrote:Thanks Boris,
I have the same problem, started acting up day before yesterday. A reboot in each of the last 2 days got data to push to Wunderground. Today however it will not restore the push. Tried going back to previous software versions but that didn't fix it. Any suggestions?
logger (17.02.2016 13:25:14): station 0 (Vantage), can't open device /dev/ttyMH: No such file or directory
Thank you!
Are you using the mandatory USB hub?
