Meteohub disappear after a while
Armond
Post by Armond »
I have installed meteohub on my RPi 2 with Rfxtrx433e. It works fine to log in, but after a while I can not reach the meteohub, it seems to disappear.
It also disappear from network and internet in the control panel.
Have anyone a clue what is wrong?
If I reboot the RPi it works again for some time, and then the same thing happens again.
Re: Meteohub disappear after a while
Did you check this post? viewtopic.php?f=60&t=10297
There are similar post and there was an update for this problem,
Is it only the web-interface or is the upload from Meteohub also stopped?
Armond
Post by Armond »
I am new at RPi and meteohub, I just installed it.
So I have not upload anything yet.
I try with putty, but no connection.
Am I doing right like the picture when I try to connect with putty?
YJB
Post by YJB »
I would recommend to use port 22 when using putty.
