3020 tp link, do not connect via WLAN **solved**
fernando_haller
Post by fernando_haller »
Hello from Argentina, I'm using meteobridge LAN works perfect, but when I connect by WLAM does not.
"Setup Networks" was full and still connected only by LAN. Someone may say as set by OpenWRT.
Clarification: In expert mode only appears LAN, WLAN appears disconnected.
Sorry for the bad English, I'm using translate.google :| :| :| :|
Re: 3020 tp link, do not connect via WLAN
Please stay away from expert mode. Setup of WLAN client credentials work with the standard meteobridge web interface.
What exactly is the problem?
fernando_haller
WLAN is configured, but the restart and remove the LAN cable is not connected to the router
fernando_haller wrote:but the restart and remove the LAN cable is not connected to the router
Sorry, I don't understand this.
wsnoordbergum
Post by wsnoordbergum »
It might be easier to use the link: config.meteobridge.com
In this simulation you enter all your settings especially those of your wireless SSID, password etc. and the station settings can be done here also.
Then hit the tab download, and save the file onto a USB stick in the root directory f.i. F:, not in a subdirectory!
Power down meteobridge, insert the USB stick then power up your meteostick.
If everything goes well, meteobridge will start normal and is set to your own network etc.
Then remove the stick and connect your station.
It's easier to reserve a ip adress for your meteobridge within a network, so it allways has the same ip.
When configured properly you can enter the ip adress in your browser and log onto the meteobridge and check your settings.
Goodluck wsNoordbergum.
fernando_haller
IFCONFIG:
br-lan Link encap:Ethernet HWaddr 14:CC:20:94:BE:78
inet addr:192.168.55.103 Bcast:192.168.55.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2005 errors:0 dropped:0 overruns:0 frame:0
TX packets:1298 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2909885 (2.7 MiB) TX bytes:96539 (94.2 KiB)
eth0 Link encap:Ethernet HWaddr 14:CC:20:94:BE:78
RX packets:2019 errors:0 dropped:0 overruns:0 frame:0
collisions:0 txqueuelen:1000
RX bytes:2942772 (2.8 MiB) TX bytes:96539 (94.2 KiB)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
RESOLV.CONF:
# Interface lan
nameserver 192.168.55.1
ROUTE:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.55.1 0.0.0.0 UG 0 0 0 br-lan
192.168.55.0 * 255.255.255.0 U 0 0 0 br-lan
NSLOOKUP:
Server: 192.168.55.1
Address 1: 192.168.55.1
Address 1: 2607:5300:100::38
Address 2: 198.50.144.56 tau.meteobridge.com
fernando_haller
I will prove to configure from config.meteobridge.com, you then notice
Are you sure that your router uses WEP encryption? As WEP is very unsecure most WLANs make use of WPA.
fernando_haller
the pen driver configure method, and it did not work, change of WEP and WPA connection does not work
Can you please give me access as explained here:
viewtopic.php?f=57&t=9885
fernando_haller
ok, I was sent URL and PASS, to info@meteo ...
Thanks, I can login. My finding is that Meteobridge does not see any WLAN SSIDs.
Are you sure that it is a 2.4GHZ WLAN (b/g/n) and not a 5GHz (a) which is not
supported by the MR3020 hardware.
As you see, the drop-down with SSIDs to connect to is empty.
Screen Shot 2016-01-04 at 19.42.12.png (17.16 KiB) Viewed 9232 times
fernando_haller
the router tp link TL-WR941N working properly. I do not appear ssids
Hidden SSIDs are not working with Meteobridge.
fernando_haller
I found the problem in the router.
Thanks for your time
