i had my new MB-Pro working fine for some days with my Vantage Pro2 and upload to WU and get some XML Data via XML in my HomeMatic System.
After a few Days now, i get no fresh Data from my Vantage. I have no idea why. The Davis Console is showing new data.
So i have made a reboot (at now i hvae full normaly access to the webgui) and the the MB stuck in the landing page.
First i make a LAN Reset - same result.
Then i go to Factory settings with the same result. LED i still fast flashing and LCD shows my LAN IP.
IFCONFIG:
br-lan Link encap:Ethernet HWaddr C4:93:00:05:DD:90
inet addr:10.10.10.14 Bcast:10.10.10.255 Mask:255.255.255.0
inet6 addr: fe80::c693:ff:fe05:dd90/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5095 errors:0 dropped:0 overruns:0 frame:0
TX packets:5042 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:640763 (625.7 KiB) TX bytes:1239507 (1.1 MiB)
eth0 Link encap:Ethernet HWaddr C4:93:00:05:DD:90
RX packets:6365 errors:0 dropped:6 overruns:0 frame:0
TX packets:5058 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1072774 (1.0 MiB) TX bytes:1240799 (1.1 MiB)
Interrupt:5
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:7808 errors:0 dropped:0 overruns:0 frame:0
TX packets:7808 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:663162 (647.6 KiB) TX bytes:663162 (647.6 KiB)
RESOLV.CONF:
search lan
nameserver 127.0.0.1
ROUTE:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 10.10.10.1 0.0.0.0 UG 0 0 0 br-lan
10.10.10.0 * 255.255.255.0 U 0 0 0 br-lan
NSLOOKUP:
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost
Address 1: 2607:5300:100::38
Address 2: 198.50.144.56 tau.meteobridge.comWhen i open the link to the configurator i get these error message in red on top.
Error: Cannot allocate session directory (/home/boris/meteobridge/htdocs/cd/config-Q2XOMw): Disk quota exceeded
Error: Open file for write failed (/home/boris/meteobridge/htdocs/cd/config-Q2XOMw/www/meteobridge.conf): No such file or directoryAntworten auch gerne auf deutsch, habe gesehen, hier wird in mehrere Sprachen gearbeitet. Habe es mal auf english versucht
Greets,
landwirt
