Running Meteobridge with the newest firmware. When I try to upgrade the firmware on the MeteoStick, it fails.
System
Platform: D-LINK DIR-505 REV. A1 (no USB hub)
RAM: 61556 kB total, 28676 kB free (53% used)
SW Version: Meteobridge 2.8 (Mar 19 2016, build 9591), FW 1.3
Uptime: 1 hours, 25 minutes Buffer Usage: 0 items (0%)
logger (19.03.2016 12:56:46): Historical data loaded (29 records).
logger (19.03.2016 12:56:46): data logger (version 5.0p, build 9591) started.
logger (19.03.2016 12:56:47): connect station 0 (Meteostick Vantage via USB serial).
logger (19.03.2016 12:56:49): transmitter 1 registered as ISS
logger (19.03.2016 12:56:49): Meteostick Version 2.3b1
logger (19.03.2016 12:56:49): debug off
logger (19.03.2016 12:56:49): verbose off
logger (19.03.2016 12:56:49): output raw (8 bytes)
logger (19.03.2016 12:56:49): output raw (10 bytes)
logger (19.03.2016 12:56:49): filter on
logger (19.03.2016 12:56:49): rx threshold set to -70db
logger (19.03.2016 12:56:49): listening to transmitter 1
logger (19.03.2016 12:56:49): bandwidth narrow
logger (19.03.2016 12:56:49): chip authentication ok: 14
logger (19.03.2016 12:56:49): frequency band 915MHz (US)
MeteoStick Firmware Upgrade Fails **solved**
blacklistedcard
- Junior Boarder
Re: MeteoStick Firmware Upgrade Fails
Sometimes it needs a second try. Does it then still fail?
blacklistedcard
- Junior Boarder
I tried 6 times. Each time it failed.
blacklistedcard
- Junior Boarder
I guess I could take the MeteoStick and upgrade the firmware on a computer. I just don't get why it fails in the D-LINK DIR-505 REV. A1 Device.
I tried multiple times at once and it never update the firmware.
As I requested remote access for your machine in another thread I will take care of this as well.
blacklistedcard
- Junior Boarder
Details sent by e-mail
Was a DIR-505 specific problem. Is solved by latest update.
blacklistedcard
- Junior Boarder
Re: MeteoStick Firmware Upgrade Fails **solved**
I rebooted my DIR-505 and the newer version worked for upgrading the MeteoStick. Thanks for fixing it.
- Meteostickfixed.png (187.88 KiB) Viewed 21712 times
