Incremental alarms syntax question **solved**
mjc775
Re: Incremental alarms syntax question
Post by mjc775 »
I didn't put the brackets in the template. But when I click the 'i" icon, they are present. See photo.
FullSizeRender 2.jpg (41.75 KiB) Viewed 2438 times
Re: Incremental alarms syntax question **solved**
Thanks, that is a great hint! Looks like MB is assuming "t" is a variable and
does put some square brackets around it. This is why it is not working as expected.
Please use the "*0}" for now. I will fix the "*t}" with next update.
mjc775
Post by mjc775 »
Thank you.
