Last week I bought a new Vantage Pro 2 wireless and I managed to get it all working well with the Meteobridge Pro. I really like the flexibility for me as a web developer. But I noticed there's something wrong with the rain total amount after a reboot, when the Meteobridge Pro freezes. It happened two times now, and I can reproduce the problem.
What happens is, that when the MBP crashes or freezes, I manually reboot it (by disconnect the power cable). After the reboot the raintotal for the day is the amount that's shown on the VP2 console + the month rain total amount. So, today, I got 11mm of rain/snow here. After a reboot tonight around 20:50h the amount changed to 24.2mm. I manually changed it back to the 11mm, but I'm wondering if this problem is already known and if there's a fix for it.
I just reproduced the problem by unplugging the power cable so the MBP shuts down immediately, after that I plugged the power cable back in the MBP so it boots. After booting the rain total amount is too much:
Log:
oled (04.03.2016 10:47:59): process started.
wnetd (04.03.2016 23:36:20): process started.
test5m (04.03.2016 23:36:23): logger stalled, will be restarted now.
test5m (04.03.2016 23:36:24): database daemon stalled, will be restarted now.
logger (04.03.2016 23:36:24): database connected.
logger (04.03.2016 23:36:24): Historical data loaded (0 records).
logger (04.03.2016 23:36:24): data logger (version 5.0p, build 9385) started.
database (04.03.2016 23:36:24): process started.
logger (04.03.2016 23:36:25): connect station 0 (Vantage via USB serial).
logger (04.03.2016 23:36:25): connect station 9 (System Data via Plug-in).
logger (04.03.2016 23:36:25): wakeup sent.
logger (04.03.2016 23:36:25): internal logger activated.
logger (04.03.2016 23:36:25): syncing.
dbrepair (04.03.2016 23:36:32): database integrity checked.
logger (04.03.2016 23:36:35): gettime request sent.
logger (04.03.2016 23:36:35): no Vantage time offset.
logger (04.03.2016 23:36:35): eeprom request sent.
logger (04.03.2016 23:36:35): rain collector size 0.2 mm per tick.
logger (04.03.2016 23:36:35): transmitter 1 active as station type (#0) "ISS".
logger (04.03.2016 23:36:35): transmitter 2 active as station type (#4) "Wind".
logger (04.03.2016 23:36:35): firmware version request sent.
logger (04.03.2016 23:36:35): firmware version 3.15
logger (04.03.2016 23:36:35): no reading of Vantage's internal logger.Thanks.
