XML Livedata from MBPro send ZERO or Wrong since last update
landwirt
Post by landwirt »
Hello there,
i have a Davis VP2 and a Davis SoilStation. Booth send Data to the red MBPro.
Via the LiveXML Datasheet my HomeAutomation System gets the Weather data.
Since Update yesterday, i get often Zero or wrong Values from the MB Pro.
And the History Data are gone - i only have my Today VAlues in the History and MIN/MAX? Thats not the Problem, because i log it anotherway, but strange?
And the Rain Value only goes one Step to 0.2mm and the Back to 0.
@Admin - ive sent you my access data via PM
landwirt
Re: XML Livedata from MBPro send ZERO or Wrong since last up
Post by landwirt »
logger (03.06.2016 16:15:33): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:15:34): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:15:34): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:15:34): transmitter 1 registered as ISS
logger (03.06.2016 16:15:34): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:15:34): Meteostick Version 2.4
logger (03.06.2016 16:15:34): debug off
logger (03.06.2016 16:15:34): verbose off
logger (03.06.2016 16:15:34): output raw (8 bytes)
logger (03.06.2016 16:15:34): output raw (10 bytes)
logger (03.06.2016 16:15:34): filter on
logger (03.06.2016 16:15:34): rx threshold set to -90db
logger (03.06.2016 16:15:34): listening to transmitter 1 8
logger (03.06.2016 16:15:34): bandwidth narrow
logger (03.06.2016 16:15:34): chip authentication ok: 14
logger (03.06.2016 16:15:34): frequency band 868MHz (EU)
logger (03.06.2016 16:20:44): parent process received termination signal (15).
logger (03.06.2016 16:20:44): child process received termination signal (15).
logger (03.06.2016 16:20:44): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:20:44): disconnect station 9 (System Data): exit
database (03.06.2016 16:20:44): process terminated normally.
test5m (03.06.2016 14:20:45): USB storage remounted: /dev/sda
database (03.06.2016 16:20:45): process started.
logger (03.06.2016 16:20:46): database connected.
logger (03.06.2016 16:20:46): Historical data loaded (69 records).
logger (03.06.2016 16:20:46): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:20:47): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:20:47): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:20:47): transmitter 1 registered as ISS
logger (03.06.2016 16:20:47): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:20:47): Meteostick Version 2.4
logger (03.06.2016 16:20:47): debug off
logger (03.06.2016 16:20:47): verbose off
logger (03.06.2016 16:20:47): output raw (8 bytes)
logger (03.06.2016 16:20:47): output raw (10 bytes)
logger (03.06.2016 16:20:47): filter on
logger (03.06.2016 16:20:47): rx threshold set to -90db
logger (03.06.2016 16:20:47): listening to transmitter 1 8
logger (03.06.2016 16:20:47): bandwidth narrow
logger (03.06.2016 16:20:47): chip authentication ok: 14
logger (03.06.2016 16:20:47): frequency band 868MHz (EU)
logger (03.06.2016 16:25:45): parent process received termination signal (15).
logger (03.06.2016 16:25:45): child process received termination signal (15).
logger (03.06.2016 16:25:45): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:25:45): disconnect station 9 (System Data): exit
database (03.06.2016 16:25:45): process terminated normally.
test5m (03.06.2016 14:25:46): USB storage remounted: /dev/sda
database (03.06.2016 16:25:46): process started.
logger (03.06.2016 16:25:47): database connected.
logger (03.06.2016 16:25:47): Historical data loaded (69 records).
logger (03.06.2016 16:25:47): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:25:48): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:25:48): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:25:50): transmitter 1 registered as ISS
logger (03.06.2016 16:25:50): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:25:50): Meteostick Version 2.4
logger (03.06.2016 16:25:50): debug off
logger (03.06.2016 16:25:50): verbose off
logger (03.06.2016 16:25:50): output raw (8 bytes)
logger (03.06.2016 16:25:50): output raw (10 bytes)
logger (03.06.2016 16:25:50): filter on
logger (03.06.2016 16:25:50): rx threshold set to -90db
logger (03.06.2016 16:25:50): listening to transmitter 1 8
logger (03.06.2016 16:25:50): bandwidth narrow
logger (03.06.2016 16:25:51): chip authentication ok: 14
logger (03.06.2016 16:25:51): frequency band 868MHz (EU)
logger (03.06.2016 16:31:17): parent process received termination signal (15).
logger (03.06.2016 16:31:17): child process received termination signal (15).
logger (03.06.2016 16:31:17): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:31:17): disconnect station 9 (System Data): exit
database (03.06.2016 16:31:17): process terminated normally.
test5m (03.06.2016 14:31:18): USB storage remounted: /dev/sda
database (03.06.2016 16:31:18): process started.
logger (03.06.2016 16:31:19): database connected.
logger (03.06.2016 16:31:19): Historical data loaded (69 records).
logger (03.06.2016 16:31:19): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:31:20): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:31:20): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:31:20): transmitter 1 registered as ISS
logger (03.06.2016 16:31:20): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:31:20): Meteostick Version 2.4
logger (03.06.2016 16:31:20): debug off
logger (03.06.2016 16:31:20): verbose off
logger (03.06.2016 16:31:20): output raw (8 bytes)
logger (03.06.2016 16:31:20): output raw (10 bytes)
logger (03.06.2016 16:31:20): filter on
logger (03.06.2016 16:31:20): rx threshold set to -90db
logger (03.06.2016 16:31:20): listening to transmitter 1 8
logger (03.06.2016 16:31:20): bandwidth narrow
logger (03.06.2016 16:31:20): chip authentication ok: 14
logger (03.06.2016 16:31:20): frequency band 868MHz (EU)
logger (03.06.2016 16:35:35): parent process received termination signal (15).
logger (03.06.2016 16:35:35): child process received termination signal (15).
logger (03.06.2016 16:35:35): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:35:35): disconnect station 9 (System Data): exit
database (03.06.2016 16:35:35): process terminated normally.
test5m (03.06.2016 14:35:36): USB storage remounted: /dev/sda
database (03.06.2016 16:35:37): process started.
logger (03.06.2016 16:35:37): database connected.
logger (03.06.2016 16:35:37): Historical data loaded (69 records).
logger (03.06.2016 16:35:37): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:35:38): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:35:38): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:35:38): transmitter 1 registered as ISS
logger (03.06.2016 16:35:38): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:35:38): Meteostick Version 2.4
logger (03.06.2016 16:35:38): debug off
logger (03.06.2016 16:35:38): verbose off
logger (03.06.2016 16:35:38): output raw (8 bytes)
logger (03.06.2016 16:35:38): output raw (10 bytes)
logger (03.06.2016 16:35:38): filter on
logger (03.06.2016 16:35:38): rx threshold set to -90db
logger (03.06.2016 16:35:38): listening to transmitter 1 8
logger (03.06.2016 16:35:38): bandwidth narrow
logger (03.06.2016 16:35:38): chip authentication ok: 14
logger (03.06.2016 16:35:38): frequency band 868MHz (EU)
logger (03.06.2016 16:41:24): parent process received termination signal (15).
logger (03.06.2016 16:41:24): child process received termination signal (15).
logger (03.06.2016 16:41:24): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:41:24): disconnect station 9 (System Data): exit
database (03.06.2016 16:41:24): process terminated normally.
test5m (03.06.2016 14:41:26): USB storage remounted: /dev/sda
database (03.06.2016 16:41:26): process started.
logger (03.06.2016 16:41:26): database connected.
logger (03.06.2016 16:41:26): Historical data loaded (69 records).
logger (03.06.2016 16:41:26): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:41:27): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:41:27): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:41:27): transmitter 1 registered as ISS
logger (03.06.2016 16:41:27): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:41:27): Meteostick Version 2.4
logger (03.06.2016 16:41:27): debug off
logger (03.06.2016 16:41:27): verbose off
logger (03.06.2016 16:41:27): output raw (8 bytes)
logger (03.06.2016 16:41:27): output raw (10 bytes)
logger (03.06.2016 16:41:27): filter on
logger (03.06.2016 16:41:27): rx threshold set to -90db
logger (03.06.2016 16:41:27): listening to transmitter 1 8
logger (03.06.2016 16:41:27): bandwidth narrow
logger (03.06.2016 16:41:27): chip authentication ok: 14
logger (03.06.2016 16:41:27): frequency band 868MHz (EU)
logger (03.06.2016 16:46:40): parent process received termination signal (15).
logger (03.06.2016 16:46:40): child process received termination signal (15).
logger (03.06.2016 16:46:40): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:46:40): disconnect station 9 (System Data): exit
logger (03.06.2016 16:46:40): data logger stopped.
database (03.06.2016 16:46:41): process terminated normally.
test5m (03.06.2016 14:46:42): USB storage remounted: /dev/sda
database (03.06.2016 16:46:42): process started.
logger (03.06.2016 16:46:43): database connected.
logger (03.06.2016 16:46:43): Historical data loaded (69 records).
logger (03.06.2016 16:46:43): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:46:44): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:46:44): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:46:44): transmitter 1 registered as ISS
logger (03.06.2016 16:46:44): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:46:44): Meteostick Version 2.4
logger (03.06.2016 16:46:44): debug off
logger (03.06.2016 16:46:44): verbose off
logger (03.06.2016 16:46:44): output raw (8 bytes)
logger (03.06.2016 16:46:44): output raw (10 bytes)
logger (03.06.2016 16:46:44): filter on
logger (03.06.2016 16:46:44): rx threshold set to -90db
logger (03.06.2016 16:46:44): listening to transmitter 1 8
logger (03.06.2016 16:46:44): bandwidth narrow
logger (03.06.2016 16:46:44): chip authentication ok: 14
logger (03.06.2016 16:46:44): frequency band 868MHz (EU)
logger (03.06.2016 16:51:19): parent process received termination signal (15).
logger (03.06.2016 16:51:19): child process received termination signal (15).
logger (03.06.2016 16:51:19): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:51:19): disconnect station 9 (System Data): exit
database (03.06.2016 16:51:20): process terminated normally.
test5m (03.06.2016 14:51:21): USB storage remounted: /dev/sda
database (03.06.2016 16:51:21): process started.
logger (03.06.2016 16:51:21): database connected.
logger (03.06.2016 16:51:21): Historical data loaded (69 records).
logger (03.06.2016 16:51:21): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:51:22): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:51:22): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:51:25): transmitter 1 registered as ISS
logger (03.06.2016 16:51:25): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:51:25): Meteostick Version 2.4
logger (03.06.2016 16:51:25): debug off
logger (03.06.2016 16:51:25): verbose off
logger (03.06.2016 16:51:25): output raw (8 bytes)
logger (03.06.2016 16:51:25): output raw (10 bytes)
logger (03.06.2016 16:51:25): filter on
logger (03.06.2016 16:51:25): rx threshold set to -90db
logger (03.06.2016 16:51:25): listening to transmitter 1 8
logger (03.06.2016 16:51:25): bandwidth narrow
logger (03.06.2016 16:51:25): chip authentication ok: 14
logger (03.06.2016 16:51:25): frequency band 868MHz (EU)
logger (03.06.2016 16:55:18): parent process received termination signal (15).
logger (03.06.2016 16:55:18): child process received termination signal (15).
logger (03.06.2016 16:55:18): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 16:55:18): disconnect station 9 (System Data): exit
database (03.06.2016 16:55:18): process terminated normally.
test5m (03.06.2016 14:55:20): USB storage remounted: /dev/sda
database (03.06.2016 16:55:20): process started.
logger (03.06.2016 16:55:20): database connected.
logger (03.06.2016 16:55:20): Historical data loaded (69 records).
logger (03.06.2016 16:55:20): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 16:55:21): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 16:55:21): connect station 9 (System Data via Plug-in).
logger (03.06.2016 16:55:21): transmitter 1 registered as ISS
logger (03.06.2016 16:55:21): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 16:55:21): Meteostick Version 2.4
logger (03.06.2016 16:55:21): debug off
logger (03.06.2016 16:55:21): verbose off
logger (03.06.2016 16:55:21): output raw (8 bytes)
logger (03.06.2016 16:55:21): output raw (10 bytes)
logger (03.06.2016 16:55:21): filter on
logger (03.06.2016 16:55:21): rx threshold set to -90db
logger (03.06.2016 16:55:21): listening to transmitter 1 8
logger (03.06.2016 16:55:21): bandwidth narrow
logger (03.06.2016 16:55:21): chip authentication ok: 14
logger (03.06.2016 16:55:21): frequency band 868MHz (EU)
logger (03.06.2016 17:00:22): parent process received termination signal (15).
logger (03.06.2016 17:00:22): child process received termination signal (15).
logger (03.06.2016 17:00:22): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:00:22): disconnect station 9 (System Data): exit
database (03.06.2016 17:00:22): process terminated normally.
test5m (03.06.2016 15:00:24): USB storage remounted: /dev/sda
database (03.06.2016 17:00:24): process started.
logger (03.06.2016 17:00:24): database connected.
logger (03.06.2016 17:00:24): Historical data loaded (69 records).
logger (03.06.2016 17:00:24): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:00:25): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:00:25): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:00:25): transmitter 1 registered as ISS
logger (03.06.2016 17:00:25): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:00:25): Meteostick Version 2.4
logger (03.06.2016 17:00:25): debug off
logger (03.06.2016 17:00:25): verbose off
logger (03.06.2016 17:00:25): output raw (8 bytes)
logger (03.06.2016 17:00:25): output raw (10 bytes)
logger (03.06.2016 17:00:25): filter on
logger (03.06.2016 17:00:25): rx threshold set to -90db
logger (03.06.2016 17:00:25): listening to transmitter 1 8
logger (03.06.2016 17:00:25): bandwidth narrow
logger (03.06.2016 17:00:25): chip authentication ok: 14
logger (03.06.2016 17:00:25): frequency band 868MHz (EU)
logger (03.06.2016 17:06:07): parent process received termination signal (15).
logger (03.06.2016 17:06:07): child process received termination signal (15).
logger (03.06.2016 17:06:07): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:06:07): disconnect station 9 (System Data): exit
logger (03.06.2016 17:06:07): data logger stopped.
database (03.06.2016 17:06:08): process terminated normally.
test5m (03.06.2016 15:06:10): USB storage remounted: /dev/sda
database (03.06.2016 17:06:10): process started.
logger (03.06.2016 17:06:10): database connected.
logger (03.06.2016 17:06:10): Historical data loaded (69 records).
logger (03.06.2016 17:06:10): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:06:11): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:06:11): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:06:11): transmitter 1 registered as ISS
logger (03.06.2016 17:06:11): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:06:11): Meteostick Version 2.4
logger (03.06.2016 17:06:11): debug off
logger (03.06.2016 17:06:11): verbose off
logger (03.06.2016 17:06:11): output raw (8 bytes)
logger (03.06.2016 17:06:11): output raw (10 bytes)
logger (03.06.2016 17:06:11): filter on
logger (03.06.2016 17:06:11): rx threshold set to -90db
logger (03.06.2016 17:06:11): listening to transmitter 1 8
logger (03.06.2016 17:06:11): bandwidth narrow
logger (03.06.2016 17:06:11): chip authentication ok: 14
logger (03.06.2016 17:06:11): frequency band 868MHz (EU)
logger (03.06.2016 17:10:54): parent process received termination signal (15).
logger (03.06.2016 17:10:54): child process received termination signal (15).
logger (03.06.2016 17:10:54): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:10:54): disconnect station 9 (System Data): exit
database (03.06.2016 17:10:54): process terminated normally.
test5m (03.06.2016 15:10:56): USB storage remounted: /dev/sda
database (03.06.2016 17:10:56): process started.
logger (03.06.2016 17:10:56): database connected.
logger (03.06.2016 17:10:56): Historical data loaded (69 records).
logger (03.06.2016 17:10:56): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:10:57): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:10:57): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:10:57): transmitter 1 registered as ISS
logger (03.06.2016 17:10:57): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:10:57): Meteostick Version 2.4
logger (03.06.2016 17:10:57): debug off
logger (03.06.2016 17:10:57): verbose off
logger (03.06.2016 17:10:57): output raw (8 bytes)
logger (03.06.2016 17:10:57): output raw (10 bytes)
logger (03.06.2016 17:10:57): filter on
logger (03.06.2016 17:10:57): rx threshold set to -90db
logger (03.06.2016 17:10:57): listening to transmitter 1 8
logger (03.06.2016 17:10:57): bandwidth narrow
logger (03.06.2016 17:10:58): chip authentication ok: 14
logger (03.06.2016 17:10:58): frequency band 868MHz (EU)
logger (03.06.2016 17:16:06): parent process received termination signal (15).
logger (03.06.2016 17:16:06): child process received termination signal (15).
logger (03.06.2016 17:16:06): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:16:06): disconnect station 9 (System Data): exit
database (03.06.2016 17:16:07): process terminated normally.
test5m (03.06.2016 15:16:08): USB storage remounted: /dev/sda
database (03.06.2016 17:16:08): process started.
logger (03.06.2016 17:16:08): database connected.
logger (03.06.2016 17:16:08): Historical data loaded (69 records).
logger (03.06.2016 17:16:08): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:16:09): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:16:09): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:16:11): transmitter 1 registered as ISS
logger (03.06.2016 17:16:11): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:16:11): Meteostick Version 2.4
logger (03.06.2016 17:16:11): debug off
logger (03.06.2016 17:16:11): verbose off
logger (03.06.2016 17:16:11): output raw (8 bytes)
logger (03.06.2016 17:16:11): output raw (10 bytes)
logger (03.06.2016 17:16:11): filter on
logger (03.06.2016 17:16:11): rx threshold set to -90db
logger (03.06.2016 17:16:11): listening to transmitter 1 8
logger (03.06.2016 17:16:11): bandwidth narrow
logger (03.06.2016 17:16:11): chip authentication ok: 14
logger (03.06.2016 17:16:11): frequency band 868MHz (EU)
logger (03.06.2016 17:21:21): parent process received termination signal (15).
logger (03.06.2016 17:21:21): child process received termination signal (15).
logger (03.06.2016 17:21:21): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:21:21): disconnect station 9 (System Data): exit
database (03.06.2016 17:21:22): process terminated normally.
test5m (03.06.2016 15:21:23): USB storage remounted: /dev/sda
database (03.06.2016 17:21:23): process started.
logger (03.06.2016 17:21:23): database connected.
logger (03.06.2016 17:21:23): Historical data loaded (69 records).
logger (03.06.2016 17:21:23): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:21:24): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:21:24): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:21:24): transmitter 1 registered as ISS
logger (03.06.2016 17:21:24): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:21:24): Meteostick Version 2.4
logger (03.06.2016 17:21:24): debug off
logger (03.06.2016 17:21:24): verbose off
logger (03.06.2016 17:21:24): output raw (8 bytes)
logger (03.06.2016 17:21:24): output raw (10 bytes)
logger (03.06.2016 17:21:24): filter on
logger (03.06.2016 17:21:24): rx threshold set to -90db
logger (03.06.2016 17:21:24): listening to transmitter 1 8
logger (03.06.2016 17:21:24): bandwidth narrow
logger (03.06.2016 17:21:25): chip authentication ok: 14
logger (03.06.2016 17:21:25): frequency band 868MHz (EU)
logger (03.06.2016 17:25:28): parent process received termination signal (15).
logger (03.06.2016 17:25:28): child process received termination signal (15).
logger (03.06.2016 17:25:28): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:25:28): disconnect station 9 (System Data): exit
database (03.06.2016 17:25:29): process terminated normally.
test5m (03.06.2016 15:25:30): USB storage remounted: /dev/sda
database (03.06.2016 17:25:30): process started.
logger (03.06.2016 17:25:30): database connected.
logger (03.06.2016 17:25:30): Historical data loaded (69 records).
logger (03.06.2016 17:25:30): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:25:31): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:25:31): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:25:31): transmitter 1 registered as ISS
logger (03.06.2016 17:25:31): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:25:31): Meteostick Version 2.4
logger (03.06.2016 17:25:31): debug off
logger (03.06.2016 17:25:31): verbose off
logger (03.06.2016 17:25:31): output raw (8 bytes)
logger (03.06.2016 17:25:31): output raw (10 bytes)
logger (03.06.2016 17:25:31): filter on
logger (03.06.2016 17:25:31): rx threshold set to -90db
logger (03.06.2016 17:25:31): listening to transmitter 1 8
logger (03.06.2016 17:25:31): bandwidth narrow
logger (03.06.2016 17:25:32): chip authentication ok: 14
logger (03.06.2016 17:25:32): frequency band 868MHz (EU)
logger (03.06.2016 17:31:33): parent process received termination signal (15).
logger (03.06.2016 17:31:33): child process received termination signal (15).
logger (03.06.2016 17:31:33): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:31:33): disconnect station 9 (System Data): exit
logger (03.06.2016 17:31:34): data logger stopped.
database (03.06.2016 17:31:35): process terminated normally.
test5m (03.06.2016 15:31:36): USB storage remounted: /dev/sda
database (03.06.2016 17:31:36): process started.
logger (03.06.2016 17:31:36): database connected.
logger (03.06.2016 17:31:36): Historical data loaded (69 records).
logger (03.06.2016 17:31:36): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:31:37): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:31:37): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:31:37): transmitter 1 registered as ISS
logger (03.06.2016 17:31:37): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:31:37): Meteostick Version 2.4
logger (03.06.2016 17:31:37): debug off
logger (03.06.2016 17:31:37): verbose off
logger (03.06.2016 17:31:37): output raw (8 bytes)
logger (03.06.2016 17:31:37): output raw (10 bytes)
logger (03.06.2016 17:31:37): filter on
logger (03.06.2016 17:31:37): rx threshold set to -90db
logger (03.06.2016 17:31:37): listening to transmitter 1 8
logger (03.06.2016 17:31:37): bandwidth narrow
logger (03.06.2016 17:31:38): chip authentication ok: 14
logger (03.06.2016 17:31:38): frequency band 868MHz (EU)
logger (03.06.2016 17:36:07): parent process received termination signal (15).
logger (03.06.2016 17:36:07): child process received termination signal (15).
logger (03.06.2016 17:36:07): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:36:08): disconnect station 9 (System Data): exit
database (03.06.2016 17:36:08): process terminated normally.
test5m (03.06.2016 15:36:09): USB storage remounted: /dev/sda
database (03.06.2016 17:36:09): process started.
logger (03.06.2016 17:36:09): database connected.
logger (03.06.2016 17:36:09): Historical data loaded (69 records).
logger (03.06.2016 17:36:09): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:36:10): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 17:36:10): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:36:10): transmitter 1 registered as ISS
logger (03.06.2016 17:36:10): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 17:36:10): Meteostick Version 2.4
logger (03.06.2016 17:36:10): debug off
logger (03.06.2016 17:36:10): verbose off
logger (03.06.2016 17:36:10): output raw (8 bytes)
logger (03.06.2016 17:36:10): output raw (10 bytes)
logger (03.06.2016 17:36:10): filter on
logger (03.06.2016 17:36:10): rx threshold set to -90db
logger (03.06.2016 17:36:10): listening to transmitter 1 8
logger (03.06.2016 17:36:10): bandwidth narrow
logger (03.06.2016 17:36:11): chip authentication ok: 14
logger (03.06.2016 17:36:11): frequency band 868MHz (EU)
logger (03.06.2016 17:41:00): parent process received termination signal (15).
logger (03.06.2016 17:41:00): child process received termination signal (15).
logger (03.06.2016 17:41:01): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 17:41:01): disconnect station 9 (System Data): exit
database (03.06.2016 17:41:01): process terminated normally.
test5m (03.06.2016 15:41:02): USB storage remounted: /dev/sda
database (03.06.2016 17:41:02): process started.
logger (03.06.2016 17:41:02): database connected.
logger (03.06.2016 17:41:03): Historical data loaded (69 records).
logger (03.06.2016 17:41:03): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:41:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:41:03): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:41:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:42:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:42:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:43:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:43:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:44:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:44:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:45:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:45:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:46:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:46:07): parent process received termination signal (15).
logger (03.06.2016 17:46:07): child process received termination signal (15).
logger (03.06.2016 17:46:08): disconnect station 9 (System Data): exit
database (03.06.2016 17:46:08): process terminated normally.
test5m (03.06.2016 15:46:09): USB storage remounted: /dev/sda
database (03.06.2016 17:46:09): process started.
logger (03.06.2016 17:46:09): database connected.
logger (03.06.2016 17:46:09): Historical data loaded (69 records).
logger (03.06.2016 17:46:09): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:46:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:46:10): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:46:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:47:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:47:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:48:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:48:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:49:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:49:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:50:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:50:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:51:09): parent process received termination signal (15).
logger (03.06.2016 17:51:09): child process received termination signal (15).
logger (03.06.2016 17:51:10): disconnect station 9 (System Data): exit
database (03.06.2016 17:51:10): process terminated normally.
test5m (03.06.2016 15:51:11): USB storage remounted: /dev/sda
database (03.06.2016 17:51:11): process started.
logger (03.06.2016 17:51:11): database connected.
logger (03.06.2016 17:51:11): Historical data loaded (69 records).
logger (03.06.2016 17:51:11): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:51:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:51:12): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:51:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:52:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:52:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:53:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:53:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:54:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:54:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:55:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:55:30): parent process received termination signal (15).
logger (03.06.2016 17:55:30): child process received termination signal (15).
logger (03.06.2016 17:55:30): disconnect station 9 (System Data): exit
logger (03.06.2016 17:55:31): data logger stopped.
database (03.06.2016 17:55:32): process terminated normally.
test5m (03.06.2016 15:55:33): USB storage remounted: /dev/sda
database (03.06.2016 17:55:33): process started.
logger (03.06.2016 17:55:33): database connected.
logger (03.06.2016 17:55:33): Historical data loaded (69 records).
logger (03.06.2016 17:55:33): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 17:55:34): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:55:34): connect station 9 (System Data via Plug-in).
logger (03.06.2016 17:56:04): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:56:34): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:57:04): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:57:34): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:58:04): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:58:34): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:59:04): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 17:59:34): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:00:04): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:00:34): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:01:04): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:01:28): parent process received termination signal (15).
logger (03.06.2016 18:01:28): child process received termination signal (15).
logger (03.06.2016 18:01:29): disconnect station 9 (System Data): exit
database (03.06.2016 18:01:29): process terminated normally.
test5m (03.06.2016 16:01:30): USB storage remounted: /dev/sda
database (03.06.2016 18:01:30): process started.
logger (03.06.2016 18:01:30): database connected.
logger (03.06.2016 18:01:30): Historical data loaded (69 records).
logger (03.06.2016 18:01:30): data logger (version 5.0p, build 9922) started.
logger (03.06.2016 18:01:31): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:01:31): connect station 9 (System Data via Plug-in).
logger (03.06.2016 18:02:01): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:02:35): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:03:05): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (03.06.2016 18:03:35): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
landwirt
Post by landwirt »
all History Data away?
oled (03.06.2016 16:07:21): process started.
database (03.06.2016 18:09:03): process started.
wnetd (03.06.2016 18:09:03): process started.
logger (03.06.2016 18:09:04): database connected.
logger (03.06.2016 18:09:04): Historical data loaded (0 records).
logger (03.06.2016 18:09:04): data logger (version 5.0p, build 9924) started.
logger (03.06.2016 18:09:05): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 18:09:05): connect station 9 (System Data via Plug-in).
logger (03.06.2016 18:09:07): transmitter 1 registered as ISS
logger (03.06.2016 18:09:07): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 18:09:07): Meteostick Version 2.4
logger (03.06.2016 18:09:07): debug off
logger (03.06.2016 18:09:07): verbose off
logger (03.06.2016 18:09:07): output raw (8 bytes)
logger (03.06.2016 18:09:07): output raw (10 bytes)
logger (03.06.2016 18:09:07): filter on
logger (03.06.2016 18:09:07): rx threshold set to -90db
logger (03.06.2016 18:09:07): listening to transmitter 1 8
logger (03.06.2016 18:09:07): bandwidth narrow
logger (03.06.2016 18:09:07): chip authentication ok: 14
logger (03.06.2016 18:09:07): frequency band 868MHz (EU)
logger (03.06.2016 18:09:12): parent process received termination signal (15).
logger (03.06.2016 18:09:12): child process received termination signal (15).
logger (03.06.2016 18:09:12): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 18:09:12): disconnect station 9 (System Data): exit
database (03.06.2016 18:09:13): process terminated normally.
test5m (03.06.2016 18:09:14): USB storage remounted: /dev/sda
database (03.06.2016 18:09:14): process started.
logger (03.06.2016 18:09:14): database connected.
logger (03.06.2016 18:09:14): Historical data loaded (0 records).
logger (03.06.2016 18:09:14): data logger (version 5.0p, build 9924) started.
logger (03.06.2016 18:09:15): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 18:09:15): connect station 9 (System Data via Plug-in).
logger (03.06.2016 18:09:17): transmitter 1 registered as ISS
logger (03.06.2016 18:09:17): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 18:09:17): Meteostick Version 2.4
logger (03.06.2016 18:09:17): debug off
logger (03.06.2016 18:09:17): verbose off
logger (03.06.2016 18:09:17): output raw (8 bytes)
logger (03.06.2016 18:09:17): output raw (10 bytes)
logger (03.06.2016 18:09:17): filter on
logger (03.06.2016 18:09:17): rx threshold set to -90db
logger (03.06.2016 18:09:17): listening to transmitter 1 8
logger (03.06.2016 18:09:17): bandwidth narrow
logger (03.06.2016 18:09:17): chip authentication ok: 14
logger (03.06.2016 18:09:17): frequency band 868MHz (EU)
logger (03.06.2016 18:11:30): parent process received termination signal (15).
logger (03.06.2016 18:11:30): child process received termination signal (15).
logger (03.06.2016 18:11:30): disconnect station 0 (Meteostick Vantage): exit
logger (03.06.2016 18:11:30): disconnect station 9 (System Data): exit
database (03.06.2016 18:11:30): process terminated normally.
test5m (03.06.2016 18:11:31): USB storage remounted: /dev/sda
database (03.06.2016 18:11:31): process started.
logger (03.06.2016 18:11:32): database connected.
logger (03.06.2016 18:11:32): Historical data loaded (45 records).
logger (03.06.2016 18:11:32): data logger (version 5.0p, build 9924) started.
logger (03.06.2016 18:11:32): connect station 0 (Meteostick Vantage via USB serial).
logger (03.06.2016 18:11:32): connect station 9 (System Data via Plug-in).
logger (03.06.2016 18:11:34): transmitter 1 registered as ISS
logger (03.06.2016 18:11:34): transmitter 8 registered as Leaf/Soil
logger (03.06.2016 18:11:34): Meteostick Version 2.4
logger (03.06.2016 18:11:34): debug off
logger (03.06.2016 18:11:34): verbose off
logger (03.06.2016 18:11:34): output raw (8 bytes)
logger (03.06.2016 18:11:34): output raw (10 bytes)
logger (03.06.2016 18:11:34): filter on
logger (03.06.2016 18:11:34): rx threshold set to -90db
logger (03.06.2016 18:11:34): listening to transmitter 1 8
logger (03.06.2016 18:11:34): bandwidth narrow
logger (03.06.2016 18:11:35): chip authentication ok: 14
logger (03.06.2016 18:11:35): frequency band 868MHz (EU)
landwirt
Post by landwirt »
One Problem may be, that the Datalogger restarts suddenly and the XML shows an error instead of datas. Then every second the logger comes back with more data until it is normal.
So the result is that the rain gehts never over 0.2mm before there is an restart.
ive testet FW 2.8 and 2.9 and get same problems. Before Update, it works fine
landwirt
Post by landwirt »
now its raining again...
The XML livedata goes maximal up to 0,2mm. The liveData Tab in the WebGui shows the sum since restart
landwirt
Post by landwirt »
Whats going up with the MbPRo?
After a few hous working, wih the problems above, there a no XML Data.
logger (04.06.2016 20:26:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (04.06.2016 20:26:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (04.06.2016 20:27:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (04.06.2016 20:27:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (04.06.2016 20:28:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (04.06.2016 20:28:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (04.06.2016 20:29:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
Can you please give me remote access? Please send credentials to "info(at)meteobridge.com".
