Local Data Share on PC all folder are gone? **solved**
marco
Post by marco »
hi
my share on the PC: \\192.xxx.1.xxx\data
is complete empty all templates are gone! :shock: :shock:
thanks for help
Can Someone provide me the original folders (Template, export, more? ) I don't remember and all the Original Standard-templates in it, for display etc.?
many thanks in advance!
marco
just send it via private message !
marco
Re: Local Data Share on PC all folder are gone?
Post by marco »
marco wrote:hi
thanks for help
marco
Ok not shure what it is, but on every reboot, the Display shows; "formate storage" after few second (about 45sec) it changes to: "format failed"
After that it shows the Local IP-adress and I can acces the MB-PRO over the browser.
But there are no Live Data anymore, this morning when i started this post at least i had the livedatas. so it seems to be getting worse.
I can't use the local share \\192.xxx.1.xxx\data, even if I create folders by my own, after every reboot the DATA folder ist empty I think cause of the format-process at startup. So that means there are no templates to load up via FTP or show/change the display info!
Thanks for help!
marco
Marco, The "Format Storage" and "Format Failed" is an indication that the internal USB has failed, hence why the local share is gone along with the associated folders. No point in manually replacing these folders as they will disappear every time you reboot the unit apart from the fact there's no place to store data.
If the unit is booting all the way through you could confirm this by changing the "Database media:" on the System tab / Maintenance box from "internal USB storage" to "USB STICK on front panel" and put a USB stick in the front panel and reboot.
To replace the internal USB you will need to talk to Boris.
marco
Post by marco »
Mattk wrote:Marco, The "Format Storage" and "Format Failed" is an indication that the internal USB has failed, hence why the local share is gone along with the associated folders. No point in manually replacing these folders as they will disappear every time you reboot the unit apart from the fact there's no place to store data.
Hi Mattk
thanks for your quick reply... so simple...., it works perfect.
marco
Re: Local Data Share on PC all folder are gone? **solved**
@marco: Can you give me access to your system or can you send me output of browsing
"http://ip-of-your-mbpro/cgi-bin/system.cgi?dmesg" to "info@meteobridge.com".
marco
Post by marco »
Hi Boris
Infos sent, thanks..!
