Raspberry Pi 3
schlosser
Raspberry Pi 3
Post by schlosser »
Guten Tag
Hat schon maljemand die Software auf einem raspberry pi 3 zum laufen bekommen?
liebe Grüsse Stefan
blacklistedcard
Re: Raspberry Pi 3
Post by blacklistedcard »
Is there any image for the Raspberry PI 3?
blacklistedcard
Re: Raspberry Pi 3
Looking forward to an PI 3 image. It would have the wifi built-in
Re: Raspberry Pi 3
I have one here, but currently no time to do a port. Will take some more time, sorry...
Spi
Re: Raspberry Pi 3
Post by Spi »
Looking forward to an PI 3 image, too.
May it is possible to support you, or exists a workarround?
Greetings, Spi
Manhart
Re: Raspberry Pi 3
Post by Manhart »
Any news about the image for Raspberry 3 ?
Manhart
Re: Raspberry Pi 3
Post by Manhart »
I moved my current Meteohub 5.0q from my Raspberry Pi 2 to my new Raspberry Pi 3 with the following steps:
  • 1) Download the latest image 5.0p from the website
    2) Install image on a new SD card
    3) Put SD card in a Raspberry Pi 1 or 2
    4) Connect only network and power to the Raspberry Pi
    5) Wait for the installation of Meteohub
    6) Connect with ssh to the Rapsberry Pi
    7) Run: apt-get update
    8] Run: apt-get upgrade
    9) Run: rpi-update
    10) Reboot the Raspberry
    11) Check, if the system runs fine
    12) Switch off the system
    13) Move the SD card to the new Raspberry Pi 3
    14) Start the new Raspberry Pi 3 with the new SD card from the old Raspberry Pi
    15) The system starts fine on the new Raspberry Pi 3
    16) Transfer all data and parameters from the old Meteohub to the new one including the transfer of the license
I used this procedure to avoid problems with my running system. I hope this helps others to move the system to the Raspberry Pi 3.
Matthias
