Sensor List
easyas12mb
Sensor List
Post by easyas12mb »
Can someone explain the multiple sensors available on my system?
I have a wireless Davis Vantage Pro2 Plus. The wind, solar and UV are located on a secondary wireless transmitter.
It seems like there are some unnecessary duplication of entries?
PLEASE -- Ignore the duplication due to four screenshots being pasted together (such as rain2total, thb0seapress, wind1chill)
Re: Sensor List
Which "duplicates" are worrying you? Are there sensors listed twice?
easyas12mb
Re: Sensor List
There are Rain0 and Rain2 (4 different types)
Th0 and Th1 (3 types)
Th0 and Th2 (2 types)
Thb0 and Thb9 (6 types)
Wind0 and Wind2 (6 types)
Re: Sensor List
Idea behind sensor naming is that it consists of 3 parts:
  • sensor type: "th" stands for combined temperature and humidity sensor, ...
  • sensor id: first and primary outdoor sensor is labeled "0", additional sensors get other ids.
  • measurement: sensors can give more than one piece of information. "th" sensors for example give temperature ("temp") and humidity ("hum") and Meteobridge also provides dew point ("dew") as separate data, which is computed form temp and hum.
Therefore, you see three "th0" entries: "th0temp", "th0hum", "th0dew" which all represent different pieces of data from the "th0" sensor.
aviationmet
Re: Sensor List
Post by aviationmet »
I have a similar question, I think. We also have the Davis Vantage Pro2 Plus, only we only have the wind on a separate transmitter. We currently have the WeatherBridge (not PRO) connected via USB hub to the Davis console via it's datalogger. We've been having a lot of connectivity issues over the last month or so (WeatherBridge seemingly randomly disconnects from the internet, cannot access via browser, stops sending data to WU and other online services, etc.) and are thinking of upgrading to the PRO.
With the WeatherBridgePro, is it possible to get the data from the ISS (main sensor suite) and the wind transmitter without having the WeatherBridgePro connected to the console via the Davis Datalogger?
easyas12mb
Re: Sensor List
Yes, the Weather Bridge Pro (MeteoBridge Pro) can connect to multiple transmitters. I have a wireless Davis Vantage Pro2 Plus with temp and rain connected. The wind, solar and UV are located on a secondary wireless transmitter.
aviationmet
Re: Sensor List
Great, thanks! I mostly gathered that from your post, but before spending the money, just wanted to double check.
