Build 10240 - no gust or last hour rain
plex
Post by plex »
Hi
With latest version 10240, I don't see gust or last hour data in display or webpage anymore. Furthermore I've seen FTP problems after running a few hours, and problems uploading to wunderground (something with wget or wput error).
Kind Regards
Hans
plex
Re: Build 10240 - no gust or last hour rain
Post by plex »
After another reboot, my gust and last hour rain is back... Also stable for the last 24 hour, so I guess problem solved by it self :)
Re: Build 10240 - no gust or last hour rain **solved**
Bugs solving themselves would be a great innovation and highly welcome... :mrgreen:
I haven't changed code since August 2, so I can't be found guilty in that respect ;-)
plex
Post by plex »
Unfortunately I had to shutdown the MB today - due to VP2 cleaning :)
After powering up I miss gust and last hour rain again.
Remote login would be great. Otherwise, hard to find the reason.
It might take a minute as both ("gust" for windchill computation
and "sea level pressure" for pressure correction) need outdoor temperature.
If this data is not coming through, it will have the side effect you see.
plex
Post by plex »
admin wrote:Remote login would be great. Otherwise, hard to find the reason.
Off course - login details sent
I noticed delay of sea level pressure, but still no gust or last hour rain in display or webpage. However gust records are recorded and displayed on my webpage.
When I look at the variables you us I see not defined "converters".
[wind0wind-avg1=m/s.1:--] here "m/s" is not defined and results to replacement pattern "--"
[rain0total-sumday=mm.1:--] here "mm" is not defined
When you stay with the ISO units like m/s, mm, hPa, etc... no converter is needed.
Therefore, "[wind0wind-avg1.1:--]" and "[rain0total-sumday.1:--]" will do as you expect.
plex
Post by plex »
admin wrote:When I look at the variables you us I see not defined "converters".
Thanks for explaning... So this is the reason why display fails on wind and rain?
The strange thing is, that I haven't changed my setup for a long time, and problem came after latest release.
Still I'm missing gust on my webpage - I'll have to dig deeper into this.
Should be fixed with just uploaded SW version 10242 from August 3.
plex
Post by plex »
admin wrote:Should be fixed with just uploaded SW version 10242 from August 3.
[wind0wind-max10:0] still returns 0
http://vejrstationen.dk/weather28/uploadMB/realtime.txt
You should check your Meteobridge Live data tab as you are using a separate windsensor.
Are there multiple windsensors on the Live data tab?
If so, is the correct one having the primary color?
Use your mouse to hover and there will be a selection to define the sensor as primary: "Click to use ***** as your primary sensor"
The calculation for certain values is/was only done for primary sensors in the past.
just did another update to have this finally fixed.
plex
Post by plex »
admin wrote:just did another update to have this finally fixed.
Thanks a lot :!:
I have my gust back :)
plex
Post by plex »
This morning I noticed, that gust was "frozen" - no updating. After a reboot it's stucked on 0 again...
No rush fixing, but just for your information
Just logged in on your MBP and you are right. Funny thing is that when I restart the data logger that it works again fine.
This will need some deeper inspection.
