Bug in Meteobridge PRO **solved**
MeteoOudkarspel
Post by MeteoOudkarspel »
Hi Boris,
Today I found a bug in the version of 13 Nov 2016.
The metebridge throws an hour or three are from the data logger.
After a restart of the metebridge is good, and the same problem again after 3 hours.
Like as soon as possible solution.
Meteobridge PRO
Meteobridge 3.1 (Nov 13 2016, build 10731), FW 1.4
Sincerely,
miraculon
Re: Bug in Meteobridge PRO
Post by miraculon »
I have needed to restart the PRO three times since 13 November 2016. Uploads give a red X status on the Live Data page and there was no data or graphs available under the History tab. Must I revert the FW or is there a fix coming? The PRO was stable for many weeks prior to 13 Nov.
Greg
ralexander5
Post by ralexander5 »
Seeing same or similar issue here. Runs fine for 2 to 3 hours and then random function quit. Got some out of RAM messages earlier, but with latest reboot messages field is blank. Reverting to 3.0 has no issues.
MeteoOudkarspel
We have the same problem.
I'm glad I'm not only has this.
So like a solution to this problem.
Sincerely,
JPB
Post by JPB »
Yes, I have the same problem. I woke up this morning to messages from multiple weather networks saying "You have not sent data in some time."
It seems that, after a period of time, at least Weather Underground successfully got info - for a short time - then stopped again. The times for my messages from Weather Underground were:
3:40AM (California time): Stopped Reporting
4:00AM: Back online
6:40AM: Stopped Reporting
---reboot---
6:50AM: Back online
...obviously the reboot cleared things, but I know it will just fail again soon...
droiddk
Post by droiddk »
ralexander5 wrote:Seeing same or similar issue here. Runs fine for 2 to 3 hours and then random function quit. Got some out of RAM messages earlier, but with latest reboot messages field is blank. Reverting to 3.0 has no issues.
Maybe its related to the missing solar data? No solar data = wrong/no value to upload so upload fails. Are you using replacement values?
miraculon
Post by miraculon »
I have solar data, and I have the same issue.
Greg
webcam
Post by webcam »
For me the same problem 2-3 hours and then no more data.
My test rig is running fine, so I am a bit surprised.
When you can send my remote login information, I have a chance to check on your rig.
Please send to "info@meteobridge.com".
Are there any indications what does go wrong in the system logs?
Do you see RAM usage going up over time? Which might be a root cause (without me understanding why at the moment).
Hold on, I found the bug... There are some test messages printing out onto ramdisk which fill up RAM over time.
I just compiled a new version. Please reboot and this problem should have gone.
Sorry for the trouble!
MeteoOudkarspel
Boris may I thank you heartily.
The bug has been fixed.
Meteobridge runs again perfectly.
Sincerely,
miraculon
Post by miraculon »
I installed the update and will monitor. Thanks for the prompt fix.
Greg
webcam
Post by webcam »
Merci Boris, Meteobridge runs perfectly again.
