My Meteobridge PRO cannot maintain reception of RF signals for more than a few hours at a time. I get constant dropouts: sometimes lasting minutes; sometimes hours. The tell-tail sign of a problem shows up in the log as "restart meteostick (301 secs no valid rf signal)". A more complete copy of the log from a recent restart attempting to clear another long period of no RF reception is as follows:
oled (14.01.2017 13:36:47): process started.
database (14.01.2017 08:38:20): process started.
wnetd (14.01.2017 08:38:22): process started.
system (14.01.2017 08:38:22): start of logging process initiated.
logger (14.01.2017 08:38:22): databases connected. Update interval 3600 seconds.
logger (14.01.2017 08:38:22): Historical data loaded (0 records).
logger (14.01.2017 08:38:22): data logger (version 5.0t, build 10783) started.
logger (14.01.2017 08:38:24): connect station 0 (Meteostick Vantage via USB serial).
logger (14.01.2017 08:38:24): connect station 9 (System Data via Plug-in).
logger (14.01.2017 08:38:26): transmitter 1 registered as ISS
logger (14.01.2017 08:38:26): transmitter 5 registered as Soil
logger (14.01.2017 08:38:26): Meteostick Version 2.4
logger (14.01.2017 08:38:26): debug off
logger (14.01.2017 08:38:26): verbose off
logger (14.01.2017 08:38:26): output raw (8 bytes)
logger (14.01.2017 08:38:26): output raw (10 bytes)
logger (14.01.2017 08:38:26): filter on
logger (14.01.2017 08:38:26): rx threshold set to -90db
logger (14.01.2017 08:38:26): listening to transmitter 1 5
logger (14.01.2017 08:38:26): bandwidth narrow
logger (14.01.2017 08:38:26): chip authentication ok: 14
logger (14.01.2017 08:38:26): frequency band 915MHz (US)
database (14.01.2017 08:39:36): database sync done (62 tables, 876/11432 writes)
logger (14.01.2017 08:43:27): restart meteostick (305 secs no valid rf signal)
logger (14.01.2017 08:48:30): restart meteostick (301 secs no valid rf signal)
logger (14.01.2017 08:53:31): restart meteostick (302 secs no valid rf signal)
logger (14.01.2017 09:13:54): wind0 data incomplete (missing outdoor temp for windchill)
logger (14.01.2017 09:14:04): wind0 data incomplete (missing outdoor temp for windchill)
logger (14.01.2017 09:14:07): wind0 data incomplete (missing outdoor temp for windchill)
logger (14.01.2017 09:14:09): wind0 data incomplete (missing outdoor temp for windchill)
logger (14.01.2017 09:14:14): wind0 data incomplete (missing outdoor temp for windchill)
logger (14.01.2017 09:14:22): wind0 data incomplete (missing outdoor temp for windchill)
All of this is in spite of the MBP being less than 10 meters from the ISS and with nothing more than a single pane of glass in between the two. My Davis console is another 15 meters away and never has had a reception problem. I understand the MBP receiver is not as sensitive as the one Davis uses, but I can't imagine why with such close proximity and with so few signal barriers the signal loss is so prevalent.
Any ideas on what may be going on?
Constantly losing RF signal
Re: Constantly losing RF signal
Additional info: the RF environment does not seem to be a problem. Attached is the output from a spectrum analyzer placed next to the MB Pro (you can see the ISS in the background) centered on 915 Mhz. Signal strength consistently is in the -50's and -60's dBm range from the ISS and S/N looks reasonable.
- IMG_20170114_102451.jpg (178.54 KiB) Viewed 3794 times
Can you please move the MB PRO to a better, not much IT crowded position and reduce sensitivty to -85db?
Thanks for the suggestion. I reduced the sensitivity, but cannot do much about the environment. I personally do not use any devices other than the weather station that operate in the 900 MHz band (e.g., cordless phone, Zigbee); I do suspect our local electric utility uses this band for our smart meters.
By way of update: reducing the sensitivity appears to have made a significant improvement. I have not seen a drop out for over a day now.
