Data missing in Services using "before each new month" **solved**
glennpm
Post by glennpm »
I have been running end of month reports successfully as a "one-time alarm". This month I ran it but also duplicated the "Subj # Body" and ran it as a "before each new month" service. I was hoping to eliminate the constant checking for conditions using the "one-time alarm".
The results were run correctly for the "one-time alarm" run at 11:59 PM but most data missing for the "before each new month" service. What is the problem please?
One Time Alarm Report_Page.jpg (118.16 KiB) Viewed 9082 times
Before Each New Month Report_Page_1.jpg (70.42 KiB) Viewed 9082 times
Before Each New Month Report_Page_2.jpg (17.82 KiB) Viewed 9082 times
Re: Data missing in Services using "before each new month"
Are you on latest release? Older releases had problems in that area.
glennpm
Post by glennpm »
Using this release:
SW Version: Meteobridge 3.2 (Feb 4 2017, build 10909), FW 1.4
Uptime: 27 days, 16 hours, 23 minutes Buffer: 0 items (0%)
Glenn
glennpm
Post by glennpm »
Hmm, it looks like the release I had been using should have perhaps fixed this?
"released February 4, 2017
fixes a bug that did no correctly handle events "before" and "after" day break. Time stamps used for collecting associated data were not correctly used."
I just rebooted to the latest build.
glennpm
Post by glennpm »
Hi Admin,
Is still an issue?
Please try and report.
glennpm
Post by glennpm »
It runs if I test it, which I did previously but then I had all zero entries other than rain I believe, at the month change. I'll see what happens at the end of this month. Do you think one of your recent software changes fixed this?
glennpm
Post by glennpm »
Hi Admin,
This is still broken. All entries for before month end are empty once again. Please respond.,
I need more details. Can you provide me a remote login to your rig,
so that I can see what your settings really are?
glennpm
Post by glennpm »
Remote login info sent Sunday PM
glennpm
Post by glennpm »
Hi Admin,
Did you check my setup?
glennpm
Post by glennpm »
Admin, please respond.
glennpm
Post by glennpm »
It is still broken ....
heersje
Post by heersje »
I have the same problem. I had set-up to receive a monthly overview e-mail generated before each month and it is partly empty.
glennpm
Post by glennpm »
Hi heersje,
I have an alarm set up that works and could send it to you by PM. Its not very elegant, but works. Seems the Admin isn't interested in assisting with this.
