Meteobridge Pro not sending data to the internet **solved**
JT1
Post by JT1 »
Hi
I have a Davis Vantage Pro2 (Wireless) system linked to the MBP (red) via Lan rather than WiFi. Since the 12th September 2017 Weather Underground has not received accurate data nor humidity levels. The same applies to CWOP and WOW sites. I have had the MBP since January 2017 with little issues up until now.
The MBP is showing green on all three sites and I have re-booted several times with no real resolution to this problem. My display is working and I checked the station outside just in case of problems. Very frustrating! Live data - showing 3 green ticks as I write!!!
Anyone have the same or similar issues? I read other posts but not any clearer if the same issue.
Meteobridge 3.4 (Sep 9 2017, build 11405), FW 1.4
All advice welcome.
JT
Re: Meteobridge Pro not sending data to the internet
What does the live data values look like on the MBP?
JT1
Post by JT1 »
Hi Matt
Here is the current state as of 11:40 17/09/2017.
Weather Network Status
no Weather Underground: 2017-09-17 11:36:01 Success!
no UK Met Office WOW / WOW-NL: 2017-09-17 11:20:01 Success!
no CWOP: 2017-09-17 11:34:01 Success!
Live Data
Sensor Signal Metric Data Imperial Data
Data #10 27 sec 1% system load 1% system load
Data #11 27 sec 23.6h uptime 23.6h uptime
Data #12 27 sec 3% data store usage 3% data store usage
Data #13 27 sec 88% RAM usage 88% RAM usage
Data #15 27 sec 50 processes 50 processes
Data #16 27 sec 30sec since last data 30sec since last data
Data #14 27 sec 2.14W power 2.14W power
Data #17 27 sec 5.47V voltage 5.47V voltage
Data #18 27 sec 0.39A current 0.39A current
Data #19 27 sec 4314.90kb tx data 4314.90kb tx data
Data #20 27 sec 9510.85kb rx data 9510.85kb rx data
System #9 27 sec 45.2°C 14% 1014.3hPa (1005.9hPa) 113.4°F 14% 29.95inHg (29.70inHg)
Historical Data
Cheers
JT
JT1
Post by JT1 »
Hi Matt
Here is the live data of the same page.
Historical Data
Sensor Now
11:42 Today
Sun 17 Yesterday
Sat 16 Month
Sep Year
2017 All
min max min max min max min max min max
System temp #9 45.2°C
113.4°F 43.1°C
109.6°F 45.2°C
113.4°F 43.8°C
110.8°F 49.4°C
120.9°F 43.1°C
109.6°F 53.6°C
128.5°F 31.9°C
89.4°F 57.7°C
135.9°F 31.9°C
89.4°F 57.7°C
135.9°F
System hum #9 14% 14% 15% 11% 15% 9% 15% 6% 34% 6% 34%
System dew #9 11.5°C
52.7°F 9.9°C
49.8°F 11.5°C
52.7°F 9.7°C
49.5°F 12.0°C
53.6°F 9.5°C
49.1°F 15.8°C
60.4°F 2.3°C
36.1°F 19.7°C
67.5°F 2.3°C
36.1°F 19.7°C
67.5°F
System press #9 1005.9mb
29.70inHg 1003.6mb
29.64inHg 1006.0mb
29.71inHg 1002.7mb
29.61inHg 1005.0mb
29.68inHg 982.2mb
29.00inHg 1015.5mb
29.99inHg 975.3mb
28.80inHg 1029.9mb
30.41inHg 975.3mb
28.80inHg 1029.9mb
30.41inHg
System seapress #9 1014.3mb
29.95inHg 1012.0mb
29.88inHg 1014.4mb
29.96inHg 1011.1mb
29.86inHg 1013.4mb
29.93inHg 990.6mb
29.25inHg 1023.9mb
30.24inHg 983.7mb
29.05inHg 1038.3mb
30.66inHg 983.7mb
29.05inHg 1038.3mb
30.66inHg
Data #10 cpuload 9% 0% 59% 0% 148% 0% 294% 0% 294% 0% 294%
Data #11 uptime 23.7h 12.0h 23.7h 0.0h 12.9h 0.0h 654.7h 0.0h 3543.2h 0.0h 3543.2h
Data #12 data use 3% 3% 3% 3% 3% 2% 3% 1% 3% 1% 3%
Data #13 ram use 87% 87% 88% 74% 91% 69% 92% 64% 92% 64% 92%
Data #14 power 2.33W 1.94W 2.32W 1.74W 2.54W 1.73W 2.66W 1.73W 2.81W 1.73W 2.81W
Data #15 procs 51 46 52 46 53 46 62 46 62 46 62
Data #16 data age 28s 27s 31s 27s 119s -1s 119s -1s 173s -1s 173s
Data #17 voltage 5.46V 5.46V 5.48V 5.45V 5.49V 5.45V 5.49V 5.44V 5.49V 5.44V 5.49V
Data #18 current 0.43A 0.35A 0.43A 0.32A 0.47A 0.32A 0.49A 0.32A 0.52A 0.32A 0.52A
Data #19 tx data 4466kb 2657kb 4463kb 21kb 8359kb 21kb 456626kb 11kb 2147484kb 11kb 2147484kb
Data #20 rx data 9545kb 7673kb 9540kb 57kb 8905kb 57kb 359283kb 27kb 1947527kb 27kb 1947527kb
JT
Seems like you don't receive any current data. When win, rain, outdoor temp, etc is not reporting uploads to weather networks will be void.
"Messages" section on "System" tab should give indications what goes wrong in receiving data.
BTW, can you please include proper screen dumps. The unformatted text you inserted is mostly unreadable.
JT1
Post by JT1 »
Apologies for the un readable data previously. Will get a screen shot sorted.
JT
JT1
Post by JT1 »
Here is the screen shot today attached for your appraisal. Much appreciate all your help.
JT
Screen Shot 2017-09-18 at 12.20.49.png (284.55 KiB) Viewed 6323 times
JT1
Post by JT1 »
Here is the system comments from today.
JT
Screen Shot 2017-09-18 at 12.28.13.png (45.87 KiB) Viewed 6322 times
JT1
Post by JT1 »
This is baffling too. The Davis Vantage Pro2 is selected as shown yet no green check. As below there are two checks relating to Wifi settings??
Again any thoughts much appreciated. The station dropped sending to the internet stations at 00:50 on the 12th September 2017.
Cheers
JT
Screen Shot 2017-09-18 at 12.31.48.png (316.59 KiB) Viewed 6322 times
JT1
Post by JT1 »
Hi Matt
I have re-booted my Davis weather receiver and noticed the internal RF receiver was checked on the station tab of the MBP. I removed this check and the page changed to reflect this. After re-booting the MBP unit having saved settings it now seems to be transmitting as normal. WU is now showing my data (IENGLAND746) as before.
Hope this has been solved, more by trial and luck on my part!
Many thanks again for your feedback.Really appreciated!
JT
JT1
Post by JT1 »
Here are the updated pages and comments from the system.
JT
Screen Shot 2017-09-18 at 14.47.02.png (81.58 KiB) Viewed 6317 times
Screen Shot 2017-09-18 at 14.26.44.png (366.82 KiB) Viewed 6317 times
So based on the above screen shots and just to confirm you have a MBPro (red) connected to a USB logger. The MBP (red) is connected via cable to the logger (not wireless to the VP2) & network (as opposed to WiFi)?
Connecting via USB as well as having the use RF internal ticked would have certainly been confusing things a little.
JT1
Post by JT1 »
Hi Matt,
Yes thats correct. However I hadn't adjusted anything on the MBP (red) tabs at all prior to the problem had been identified. I was alerted to the MBP when the screen was blank, normally has the the screen logo and IP/ licence number showing.
I wonder, though not certain would the latest re-build on the 9th have anything to do with it? That is identifying an RF box??? My station started having issues with data sending from the 12th. A mystery.
Many thanks again for your forbearance on my problem.
Cheers
John T
