Any way to add a logo to the webcam image overlay?
- WessexWeather
- Senior Boarder
Hi all,
I've created a neat weather data overlay for my webcam image: -
http://content.meteobridge.com/cam/ff27 ... 8238839228
There are two more things I would like to achieve...
1. Add a logo.
2. Make all or part of the image clickable to link to my website.
Are either of these things possible using Meteobridge and the 'Image Magick' type codes?
Thanks in advance,
1. Add a logo.
Thanks in advance,
Simon
Re: Any way to add a logo to the webcam image overlay?
ad 1) In general imageMagick can work with overlay logos. Only thing I can't say is how to feed the logo picture into the upload. But when the logo can be created with ImageMagick drawing commands it will work for sure.
ad 2) Actions to trigger when someone clicks a picture is not defined inside the picture but defined by the embedding HTML code.
- WessexWeather
- Senior Boarder
Thanks for your reply.
I have successfully managed to add the logo using a script run from a cron job every minute. For anyone else interested the thread can be found here: -
http://www.wxforum.net/index.php?topic= ... icseen#new
Regards,
Regards,
Simon
Cool! Thanks for sharing, as this might also be helpfull for others!
- jasonmfarrow
Simon, are you able to share the imagemagick overlay code you use? The curved rectangle boxes look great.WessexWeather wrote: Tue Oct 17, 2017 1:17 pm Hi all,
1. Add a logo.
Thanks in advance,
- jasonmfarrow
I managed to sort it myself. Took a lot of planning though: https://admin.meteobridge.com/cam/07909 ... 0122162021
- WessexWeather
- Senior Boarder
Deleted by OP.
Simon
- jasonmfarrow
If anyone else is interested here is the overlay code:
The result looks like this:
The top two lines in the picture come from the watermark of the webcam.
-resize 852x480
-fill green -draw "fill-opacity 0.6 roundrectangle 5 410 105 475 5 5"
-fill red -draw "fill-opacity 0.6 roundrectangle 110 410 210 441 5 5"
-fill blue -draw "fill-opacity 0.6 roundrectangle 110 444 210 475 5 5"
-fill black -draw "fill-opacity 0.6 roundrectangle 215 410 315 475 5 5"
-fill black -draw "fill-opacity 0.6 roundrectangle 320 410 420 475 5 5"
-fill black -draw "fill-opacity 0.6 roundrectangle 425 410 525 475 5 5"
-fill black -draw "fill-opacity 0.6 roundrectangle 530 410 630 475 5 5"
-fill blue -draw "fill-opacity 0.6 roundrectangle 635 410 735 475 5 5"
-fill black -draw "fill-opacity 0.6 roundrectangle 740 410 840 475 5 5"
-pointsize 12
-fill white -draw "text 8 425 'Temperature'"
-fill white -draw "text 218 425 'Humidity'"
-fill white -draw "text 323 425 'Pressure'"
-fill white -draw "text 428 425 'Wind'"
-fill white -draw "text 533 425 'Gust'"
-fill white -draw "text 638 425 'Rain'"
-fill white -draw "text 743 425 'Air Quality'"
-pointsize 20
-fill white -draw "text 8 447 '[th0temp-act.1:--]°C'"
-fill white -draw "text 218 447 '[th0hum-act.0:--]%'"
-fill white -draw "text 323 447 '[thb0seapress-act.1:--] hPa'"
-fill white -draw "text 428 447 '[wind0avgwind-act=mph.1:--] mph'"
-fill white -draw "text 533 447 '[wind0wind-dmax=mph.1:--] mph'"
-fill white -draw "text 638 447 '[rain0total-sumday.1:--] mm'"
-pointsize 12
-fill white -draw "text 8 465 '[hh]:[mm]'"
-fill white -draw "text 218 465 'DewPt [th0dew-act.1:--]°C'"
-fill white -draw "text 323 465 '[thb0seapress-delta3h=enbarotrend]([thb0seapress-delta3h=barotrend.2:--] hPa)'"
-fill white -draw "text 428 465 '[wind0dir-avg10.000:--]°'"
-fill white -draw "text 533 465 '[wind0wind-dmaxtime.ij:--]:[wind0wind-dmaxtime.kl:--]'"
-fill white -draw "text 638 465 '[YYYY]: [rain0total-yearsum.1:--] mm'"
-fill white -draw "text 743 445 'PM2.5: [air1!1pm-act.1:--] µg/m3'"
-fill white -draw "text 743 465 'PM10: [air1!0pm-act.1:--] µg/m3'"
-pointsize 16
-fill white -draw "text 113 428 'Max [th0temp-dmax.1:--]°C'"
-fill white -draw "text 113 462 'Min [th0temp-dmin.1:--]°C'"
-pointsize 10
-fill white -draw "text 113 438 '[th0temp-dmaxtime.ij:--]:[th0temp-dmaxtime.kl:--]'"
-fill white -draw "text 113 472 '[th0temp-dmintime.ij:--]:[th0temp-dmintime.kl:--]'"- jasonmfarrow
To increase the picture and text quality I've increased the starting resolution x2. This changed *all* the code to increase dimensions respectively:
The picture improvement can be seen here: https://admin.meteobridge.com/cam/07909 ... 0123212110. Picture quality is not good at night but then it was the cheapest camera I found that would do the job (Foscam C2M)
Ps.: The above code can be cut'n'pasted straight into the meteobridge. There is no need to put this into one long line of code.
-resize 1706x960
-fill green -draw "fill-opacity 0.6 roundrectangle 10 820 210 950 10 10"
-fill red -draw "fill-opacity 0.6 roundrectangle 220 820 420 882 10 10"
-fill blue -draw "fill-opacity 0.6 roundrectangle 220 888 420 950 10 10"
-fill black -draw "fill-opacity 0.6 roundrectangle 430 820 610 950 10 10"
-fill black -draw "fill-opacity 0.6 roundrectangle 620 820 840 950 10 10"
-fill black -draw "fill-opacity 0.6 roundrectangle 850 820 1050 950 10 10"
-fill black -draw "fill-opacity 0.6 roundrectangle 1060 820 1260 950 10 10"
-fill blue -draw "fill-opacity 0.6 roundrectangle 1270 820 1470 950 10 10"
-fill black -draw "fill-opacity 0.6 roundrectangle 1480 820 1690 950 10 10"
-pointsize 24
-fill white -draw "text 20 850 'Temperature'"
-fill white -draw "text 440 850 'Humidity'"
-fill white -draw "text 630 850 'Pressure'"
-fill white -draw "text 860 850 'Wind'"
-fill white -draw "text 1070 850 'Gust'"
-fill white -draw "text 1280 850 'Rain'"
-fill white -draw "text 1490 850 'Air Quality'"
-pointsize 38
-fill white -draw "text 20 894 '[th0temp-act.1:--]°C'"
-fill white -draw "text 440 894 '[th0hum-act.0:--]%'"
-fill white -draw "text 630 894 '[thb0seapress-act.1:--] hPa'"
-fill white -draw "text 860 894 '[wind0avgwind-act=mph.1:--] mph'"
-fill white -draw "text 1070 894 '[wind0wind-dmax=mph.1:--] mph'"
-fill white -draw "text 1280 894 '[rain0total-sumday.1:--] mm'"
-pointsize 22
-fill white -draw "text 20 930 '[hh]:[mm]'"
-fill white -draw "text 440 930 'DWPT [th0dew-act.1:--]°C'"
-fill white -draw "text 630 930 '[thb0seapress-delta3h=enbarotrend]([thb0seapress-delta3h=barotrend.2:--] hPa)'"
-fill white -draw "text 860 930 '[wind0dir-avg10.000:--]°'"
-fill white -draw "text 1070 930 '[wind0wind-dmaxtime.ij:--]:[wind0wind-dmaxtime.kl:--]'"
-fill white -draw "text 1280 930 '[YYYY]: [rain0total-yearsum.1:--] mm'"
-fill white -draw "text 1490 890 'PM2.5: [air1!1pm-act.1:--] µg/m3'"
-fill white -draw "text 1490 930 'PM10: [air1!0pm-act.1:--] µg/m3'"
-pointsize 28
-fill white -draw "text 230 850 'Max [th0temp-dmax.1:--]°C'"
-fill white -draw "text 230 918 'Min [th0temp-dmin.1:--]°C'"
-pointsize 16
-fill white -draw "text 230 876 '[th0temp-dmaxtime.ij:--]:[th0temp-dmaxtime.kl:--]'"
-fill white -draw "text 230 944 '[th0temp-dmintime.ij:--]:[th0temp-dmintime.kl:--]'"
-pointsize 42
-fill white -draw "text 20 800 'JMFweather.uk'"Ps.: The above code can be cut'n'pasted straight into the meteobridge. There is no need to put this into one long line of code.
WOW, this really looks great.
Simon, Jason, would you be fine if I add this as a standard overlay to the Meteobridge templates?
- jasonmfarrow
Hi Boris,
As Simon created the original idea (I merely copied and published) he can give the final approval. I have zero objections.
I would suggest that the last box have a couple of options.
I assign mine to Air Quality data (PM2.5/PM10 values). Simon has UV/Wm2 values. it might be worth having a box that has values everyone has but I think we've covered all the basics in the prior boxes.
- jmontamat
Good morning,
Great job !!!!!
How to add a transparent background to the url ?
Great job !!!!!
- jmontamat
In the end I got it, trial and error with meteobridge every 5 minutes.
For size 1706x960
add :
-fill black -draw "fill-opacity 0.6 roundrectangle 10 760 760 810 10 10"
For size 1706x960
add :
- Sin título.png (355.96 KiB) Viewed 5776 times
- jmontamat
And the complete code in English with solar and UV.
Thanks Simon, Jason for sharing his wonderful script.
-resize 1706x960
-fill cyan -draw "fill-opacity 0.6 roundrectangle 430 820 610 950 10 10"
-fill orange -draw "fill-opacity 0.6 roundrectangle 620 820 840 950 10 10"
-fill yellow4 -draw "fill-opacity 0.6 roundrectangle 850 820 1050 950 10 10"
-fill firebrick3 -draw "fill-opacity 0.6 roundrectangle 1060 820 1260 950 10 10"
-fill yellow -draw "fill-opacity 0.6 roundrectangle 1480 820 1690 882 10 10"
-fill violet -draw "fill-opacity 0.6 roundrectangle 1480 888 1690 950 10 10"
-fill black -draw "fill-opacity 0.6 roundrectangle 10 760 757 810 10 10"
-pointsize 24
-fill white -draw "text 860 850 'Wind Act'"
-fill white -draw "text 1070 850 'Max Wind'"
-fill white -draw "text 1280 850 'Rain Today'"
-pointsize 38
-fill white -draw "text 860 894 '[wind0avgwind-act=kmh.1:--] Km/h'"
-fill white -draw "text 1070 894 '[wind0wind-dmax=kmh.1:--] Km/h'"
-pointsize 22
-fill white -draw "text 20 930 '24hrs.([th0temp-delta24h:--]°C)'"
-fill white -draw "text 440 930 'P. ros. [th0dew-act.1:--]°C'"
-fill white -draw "text 630 930 '3hrs.([thb0seapress-delta3h:--] hPa)'"
-fill white -draw "text 860 930 'Bearing: ([wind0dir-avg10.000:--]°)'"
-fill white -draw "text 1070 930 'At: [wind0wind-dmaxtime.ij:--]:[wind0wind-dmaxtime.kl:--]'"
-fill white -draw "text 1490 850 'Solar: [sol0rad-act.0:--] Wm2'"
-fill white -draw "text 1490 918 'UVI: [uv0index-act:--] UV'"
-pointsize 28
-pointsize 16
-fill white -draw "text 230 876 'At:: [th0temp-dmaxtime.ij:--]:[th0temp-dmaxtime.kl:--]'"
-fill white -draw "text 230 944 'At:: [th0temp-dmintime.ij:--]:[th0temp-dmintime.kl:--]'"
-fill white -draw "text 1490 876 'Max: [sol0rad-dmax.0:--] Wm2'"
-fill white -draw "text 1490 944 'Max: [uv0index-dmax:--] UV'"
-pointsize 42
-fill white -draw "text 20 800 'meteosantgenis.org [DD]-[MM]-[YYYY] [hh]:[mm]'" - Attachments
- camplus.jpg (92.31 KiB) Viewed 5740 times
- jasonmfarrow
Looking very good. Thank you for sharing.
