Meteobridge „service unavailable“ **solved**
Neco
Post by Neco »
I can‘t reach the Internet Login page for my meteobridge pro (since yesterday about 13 pm). It just shows „service unavailable“ and „The server is temporarily unable to service your request (...)“. Further, i can‘t reach any graphs, that i saved as external URL and it seems that i cannot reach my network folder either.
Otherwise, sending services are working (to meteoplog for instance) and i can reach the MB pro with magicip.meteobridge.com.
Neco
Re: Meteobridge „service unavailable“
Post by Neco »
Actually, network folder works... the only thing is remote login and all external links of graphs do not work. Is it a problem in my system or does meteobridge have server issues?
The message on the Meteobridge server indicates that the remote login tunnel has not been established for some reason.
Sometimes a reboot of your Meteobridge does fix it.
Neco
Post by Neco »
I did several reboots, but it did not change anything. What happened yesterday is that my meteobridge pro device got a new IP (last number changed from 2 to 4), could this be a problem? Somehow, I don't think this should interfere with the external URL... I really don't know what to do, because everything else just works perfectly fine.
glennpm
Post by glennpm »
Same issue here on the standard Meteobridge. A reboot did not resolve my issue.
Glenn
lrosenman
Post by lrosenman »
Same here -- I can't reboot it until I'm home later.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
mthiessen
Post by mthiessen »
I'm having the same problem. I can only reboot remotely because it's in a vacation house.
What is everybody's FW version?
mthiessen
Post by mthiessen »
Using Meteobridge 3.4 (Oct 26 2017, build 11579), FW 1.4
It is the latest version. I rebooted to get rid of my cached unlimited retires. So I didn't update. Usually I update remotely by rebooting. But this time it was the latest version and didn't come back up.
Neco
Post by Neco »
Latest version here as well
Leon
Post by Leon »
Same problem here...
see screenshot.
Screen Shot 2017-11-01 at 06.12.06.png (229.37 KiB) Viewed 8460 times
Leon
Post by Leon »
Interestingly I have 3 devices of which one I can still login remotely and 2 I can not log in remotely.
I have not changed any thing.
Screenshot of working one below :
Screen Shot 2017-11-01 at 06.35.35.png (237.01 KiB) Viewed 8459 times
Ger
Post by Ger »
I have the same problem. The hardware is on an Island, far away. But the cause is not by us but the server (503 Service Unavailable).
Digging more deeply into this, I found a server problem on my side. Sorry for that.
When you reboot the Meteobridge, it should rebuild the connection fine again.
But it needs a reboot of your client.
Neco
Re: Meteobridge „service unavailable“ **solved**
Post by Neco »
Thanks!
