Hello everybody,
with me the red cross still remains.
Have the system also restarted again.
Red Cross Weather Station setup ..**solved**
- Zwischenablage01.jpg (44.97 KiB) Viewed 4204 times
Re: Red Cross Weather Station setup ..
Can you give me remote access to do some checks?
Ok, it's open .....
hello just ignore it check the livedata should be returning success see attached . its a known minor bug in meteobridge , boris this is what i was trying to explain the other day. it doesnt actually stop the data being sent.webcam wrote: Fri Nov 17, 2017 8:54 am Hello everybody,
brian
- mb.png (61.09 KiB) Viewed 4175 times
The template works fine. But Boris has indeed made an update at MB, which should solve this problem. Only with me it did not work.
With this fix it works Meteobridge 3.4 (Nov 19 2017, build 11627), FW 1.4
Thanks Boris
Thanks Boris
- Zwischenablage01.jpg (42.29 KiB) Viewed 4170 times
Ok awesome nice one Boris ... have a nice weekend..brianwebcam wrote: Sun Nov 19, 2017 8:28 am The template works fine. But Boris has indeed made an update at MB, which should solve this problem. Only with me it did not work.
Thanks Boris
