Why isn't sftp uploading? **solved**
lrosenman
Post by lrosenman »
Looks like on or about 22/Jan/2018, MeteoBridge stopped uploading via sFTP.
Why?
A reboot had the FTP start again, but I'd prefer sFTP. Did that get broken?
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Re: Why isn't sftp uploading?
"no upload" tells that the service has not been started. Can you please share a screen dump of the services page, where the FTP/SFTP service is defined?
lrosenman
Post by lrosenman »
I've reverted to ftp for now. I'll try (re)-setting up sftp tonight and post (and see if things change).
That said, it had been working fine since the addition of sftp, but on January 22, 2018 at 20:05 US/CST(UTC-6) was the last upload through multiple upgrade reboots.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
lrosenman
Post by lrosenman »
Here ya go.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Service #6 is defined as SFTP but it has a legacy FTP upload command in it "ftp://...". That does not fit. If it is selected as SFTP then it needs a SFTP fitting destination defined in Path field and vice versa. Did you try replacing "ftp://" by "sftp://"? You should also be able to strip the "ftp://" header, then the protocol is selected by the defined service.
Service #7 looks fine for legacy FTP execution.
lrosenman
Post by lrosenman »
admin wrote: Wed Feb 07, 2018 10:09 am Service #6 is defined as SFTP but it has a legacy FTP upload command in it "ftp://...". That does not fit. If it is selected as SFTP then it needs a SFTP fitting destination defined in Path field and vice versa. Did you try replacing "ftp://" by "sftp://"? You should also be able to strip the "ftp://" header, then the protocol is selected by the defined service.
I removed the ftp://un:pw@host, and it still shows no upload.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Sorry, I don't understand the " ftp://un:pw@host" removal remark.
Which service definition do you speak of? #6 or #7 and what exactly did you change?
lrosenman
Post by lrosenman »
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
When you remove all SFTP services from "Services" tab then "Live Data" tab is also expected to no longer show an SFTP entry. I checked with my system and it works es expected. Please double check.
lrosenman
Post by lrosenman »
I re-added it, and I removed (per your suggestion) the ftp://user:pass@host:port/ and left the /path/file portion.
The live data tab shows sftp no upload.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
hm... looks like I can just get a grip on this via remote login. If you like to give me a remote login please send credentials to "info(at)meteobridge.com".
lrosenman
Post by lrosenman »
Done.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Can login. When I deselect SFTP service on "services" tab and press "save" and then switch over to "Live Data" tab the SFTP entry has vanished, as expected.
Screen Shot 2018-02-09 at 19.13.52.png (26.51 KiB) Viewed 6816 times
Screen Shot 2018-02-09 at 18.59.53.png (20.52 KiB) Viewed 6816 times
I am a bit lost why this did not work when you tried or may be I did not get your point.
lrosenman
Post by lrosenman »
My concern is why doesn't SFTP work.
I'm using FTP as the backup.
Your results match mine. I'd prefer to turn off my ftp daemon on the receiving host.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
I found a bug in there. Just fixed it.
Currently this setting seems to upload fine now.
Screen Shot 2018-02-09 at 23.38.31.png (30.14 KiB) Viewed 6807 times
