Meteohub Update 2.8e (experimental)
What's hot...
DEUTSCH:
Version 2.8d hatte einen Fehler in der Darstellung von Einheiten. Dies ist mit 2.8e behoben.
Link:
Änderungen gegenüber V2.8c:
* Verbessert Kompatibilität der clientraw.txt zu Mesomap (ungetestet, "speichern" auf WD-Live Seite drücken!).
* Behebt einen Fehler bei der Anzeige mancher Seiten und Texte im UTF-8 Modus.
* Behebt einen Fehler, der zu hohe Windchill-Werte in Verbindung mit der Wettertstation TE-923 aufzeichnet.
* Fügt experimentellen Support für Wetternetzwerk "regiowetter.ch" hinzu.
ENGLISH:
Version 2.8d has a bug in displaying units. Version 2.8e fixes this.
Changes since V2.8c:
* Improves compatibility of clientraw.txt to Mesomap (untested, press "save" on WD-Live page!).
* Fixed a bug the results in faulty display of some UTF-8 characters.
* Fixed a bug that results in too high recorded wind chill values in combination with TE-923.
* Adds experimental support for weather network "regiowetter.ch".
darren7303
Re:Meteohub Update 2.8e (experimental)
Post by darren7303 »
I have just downloaded this and updated my meteohub.
Meso Map Live accepts the clientraw.txt file and the parser at TNET http://www.tnetweather.com/wd-parser.php does not list any errors.
argonaut71
Post by argonaut71 »
My configuration doesn't show anymore correct date after this update in WDL.
Web: http://www.paavolat.fi/wdl/fi
Files: http://www.paavolat.fi/wdl
Also I still have problems with scandinavian characters.
EDIT: Actually date is shown after I made station name longer??? And as a parser says there is something wrong with clientdraw.txt file.
darren7303
Did you remember to click on save?
I have ran your files through the parser and it has not come back with any problems
when having installed the update, Meteohub does a recomputation of data. When this has finished data should be fine again. If this is not the case, please give some more detail what data appears to be wrong.
argonaut71
Miracle healing has happend now it doesn't show any error. But character problem still exists.
I wouldn't call completion of data recomputation a miracle :laugh:
... but anyway fine that works now ok again.
