DEUTSCH:
Version 2.8d hatte einen Fehler in der Darstellung von Einheiten. Dies ist mit 2.8e behoben.
Link:
http://www.meteohub.de/joomla/index.php ... &Itemid=29
Änderungen gegenüber V2.8c:
* Verbessert Kompatibilität der clientraw.txt zu Mesomap (ungetestet, "speichern" auf WD-Live Seite drücken!).
* Behebt einen Fehler bei der Anzeige mancher Seiten und Texte im UTF-8 Modus.
* Behebt einen Fehler, der zu hohe Windchill-Werte in Verbindung mit der Wettertstation TE-923 aufzeichnet.
* Fügt experimentellen Support für Wetternetzwerk "regiowetter.ch" hinzu.
ENGLISH:
Version 2.8d has a bug in displaying units. Version 2.8e fixes this.
Changes since V2.8c:
* Improves compatibility of clientraw.txt to Mesomap (untested, press "save" on WD-Live page!).
* Fixed a bug the results in faulty display of some UTF-8 characters.
* Fixed a bug that results in too high recorded wind chill values in combination with TE-923.
* Adds experimental support for weather network "regiowetter.ch".
Meteohub Update 2.8e (experimental)
darren7303
- Junior Boarder
Re:Meteohub Update 2.8e (experimental)
I have just downloaded this and updated my meteohub.
Meso Map Live accepts the clientraw.txt file and the parser at TNET http://www.tnetweather.com/wd-parser.php does not list any errors.
argonaut71
- Junior Boarder
My configuration doesn't show anymore correct date after this update in WDL.
Web: http://www.paavolat.fi/wdl/fi
Files: http://www.paavolat.fi/wdl
Also I still have problems with scandinavian characters.
EDIT: Actually date is shown after I made station name longer??? And as a parser says there is something wrong with clientdraw.txt file.
darren7303
- Junior Boarder
Did you remember to click on save?
I have ran your files through the parser and it has not come back with any problems
when having installed the update, Meteohub does a recomputation of data. When this has finished data should be fine again. If this is not the case, please give some more detail what data appears to be wrong.
argonaut71
- Junior Boarder
Miracle healing has happend now it doesn't show any error. But character problem still exists.
I wouldn't call completion of data recomputation a miracle :laugh:
... but anyway fine that works now ok again.
