Disk Full
Ag2000CO
Disk Full
Post by Ag2000CO »
System stopped sending data. A Reboot brought things back to life however:
System message log shows
database (15.07.2018 15:41:16): rollback on insert forced (1) (min RAM): th0temp
database (15.07.2018 15:41:16): cannot create table (after 0 tries in 1ms): database or disk is full
database (15.07.2018 15:41:16): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
All history data is gone. On Live Data tab, only the current data is shown.
Of course with the DB failed, graphs does not show any data.
All other settings/tabs looks correct.
I have tried to delete 2017 data and Reconstruct the Database Both resulting in an Error.
Assume the USB has failed.
SW version: Meteobridge 3.7 (Jul 12 2018, build 12247), FW 1.4
Next step?
Lou
Re: Disk Full
How old is this MB Pro and presumably the USB is original?
If the USB has failed and they do have a habit of doing that especially old versions then it's very easy to replace. Boris has a video on how to replace and I believe there is a list of USB makes/models such as ATP that will fit and are more robust
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
Mine is right at a year old. Been working fine all that time. Yes original memory stick
Found the/a youtube video, don't think it is the correct video; no part numbers.
Did fined this thread with some part numbers, none really recommended viewtopic.php?f=61&t=11159&p=20407&hili ... air#p20407
Lou
Re: Disk Full
Also see the following link.
viewtopic.php?f=61&t=11084&p=23568&hilit=ATP#p23568
These are the ones I am using, ATP SLC
AF1GUFNDNC
AF4GUFNDNC
AF8GUFNDNC
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
Thanks Mattk.
Lou
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
Installed a new AF8GUFNDNC
Things seem to be working. Live Data tab looks like data is being collected except for the "ALL" columns for the external sensors that are blank.
message log now shows the database is locked. That looks better than "full". I do not remember, is that correct?
database (21.07.2018 11:38:03): cannot insert into thb0temp_hour RAM (after 100 tries in 9120ms): database is locked
database (21.07.2018 11:38:03): rollback on insert forced (2) (min): thb0temp
database (21.07.2018 11:38:12): cannot commit RAM (after 100 tries in 9014ms): database is locked
database (21.07.2018 11:38:22): cannot insert into thb0temp_hour RAM (after 100 tries in 9140ms): database is locked
database (21.07.2018 11:38:22): rollback on insert forced (2) (min): thb0temp
database (21.07.2018 11:38:31): cannot commit RAM (after 100 tries in 9015ms): database is locked
database (21.07.2018 11:38:40): cannot insert into thb0temp_hour RAM (after 100 tries in 9118ms): database is locked
database (21.07.2018 11:38:40): rollback on insert forced (2) (min): thb0temp
database (21.07.2018 11:38:49): cannot commit RAM (after 100 tries in 9014ms): database is locked
Just had the a small cloud burst. Live Data shows a rain rate of 0.4in/hr, but "NO" rain total. Again looks like a lack of history storage i.e. "database locked."
Lou
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
Another reboot and another summer shower and thing seem to be working, history being collected and sent.
As an aside the thumb drive that failed in the MB seems to work with my PC.
Lou
Re: Disk Full
I am pretty sure the stick has problems. May be it works some time fine again, until the next reallocation of a bad block fails again. What kind of USB stick is it? INTENSIO?
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
I agree I wouldn't trust it. I just stuck it in to see. Somewhere I have an exhaustive test, when I have time.
The original part is a 1GB ATP NANO DURA (the "O" and "D" are questionable).
Lou
Re: Disk Full
The ATP NANO DURAs are very reliable. Then I don't think it is related to that.
Can you please give me a remote login? FAQ explains how. All I need is URL and password.
Please send to "info(at)meteobridge.com".
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
Yes I was hopping that the ATP parts were reliable. Remote access on the way - well shortly.
Lou
Ag2000CO
Re: Disk Full
Post by Ag2000CO »
Any info? Or not had time to look.
Lou
Re: Disk Full
As far as I remembered I logged in but could not find any isue. Please send me your credentials again, when you have the problem visible.
Drurak
Re: Disk Full
Post by Drurak »
Hello, i got a disk full notification in pro-black today.
If I look at the share and it said only 512 k avalaible.
What are the option for checkking of the internal disk?
greets.
system-log
system-log
share properties
share properties
Re: Disk Full
That is the internal drive and it is full, all 512k of it, you need to do some data management and clean it out or replace it with a bigger capacity.
