Just starting to play with the services. I assumed that the email service would be an easy place to start. But having no luck.
Reading here I notice that there should (may) be an error message, however I get none. As a test I deleted the "To Addr" before pressing <Test Email> ~ no error reported.
Screen shot normal settings
I have no clue where to start. Settings work from Thunderbird
Lou
First just double check the Authentication for what your email service requires as well as the port# as well as your User settings which may or may not be a full email address but must match the password in relation to the From Addr
SMTP error 504 is given by the server when a command parameter is not inplemented. Looks like your own-grown SMTP server does have a hickup. A look at its log files might give more insight.
