Services Error message
Ag2000CO
Post by Ag2000CO »
Just starting to play with the services. I assumed that the email service would be an easy place to start. But having no luck.
Reading here I notice that there should (may) be an error message, however I get none. As a test I deleted the "To Addr" before pressing <Test Email> ~ no error reported.
Screen shot normal settings Image
I have no clue where to start. Settings work from Thunderbird
Lou
Re: Services Error message
First just double check the Authentication for what your email service requires as well as the port# as well as your User settings which may or may not be a full email address but must match the password in relation to the From Addr
Ag2000CO
Post by Ag2000CO »
Double checked the Server name, port, username and password. Changed the "From address" to Admin{AT}knob.com to remove a variable.
Did a <save> to be sure then a <Test email> same results.
Just to be sure tried with and without the PIA. The MB should not be affected but...
Lou
Ian.
Post by Ian. »
maybe smtp.knob.com
CWOP - DW3371
PWS - ICAMBRID16
https://www.chatteris.biz
Ag2000CO
Post by Ag2000CO »
Thanks for the suggestion. mail[dot]xxx is confirmed. I think it is a password Authentication issue.
Back to my host.
Lou
Ag2000CO
Post by Ag2000CO »
I found a clue! If I create a email event, and then <Test Email> I get an error message
Of course lking[at]knob.com is valid. using https://mail... gets us down to a timeout error.
and how do you fix that?
Lou
SMTP error 504 is given by the server when a command parameter is not inplemented. Looks like your own-grown SMTP server does have a hickup. A look at its log files might give more insight.
Ag2000CO
Post by Ag2000CO »
Perhaps. My mail servers hosted by hub.org are working fine with with Thunderbird.
Lou
