HomeWeatherStation Dashboard
Leon
Post by Leon »
I have enabled HomeWeatherStation Dashboard on my NANO SD and can access it via my tablet and phone data upload correctly and on tablet I can access graphs etc !!
But I have a couple of questions.
Can I change the settings ?
When I log into settings I am asked for a password.
The weather station time displays UTC time and not local...can I change that.
The name says somewhere weather station....can I change that.
It does not access my web cam but a different one.
I have Meteobridge camera enabled and local URL uploads...I can see cam with overlay in my meteotemplate web site.
Please see attachments.
Any help would be appreciated ! :D :)
Regards,
Leon.
Image 2.png (112.31 KiB) Viewed 4590 times
Re: HomeWeatherStation Dashboard
Yes change the settings, first time into settings leave box blank and click login, change whatever settings you want including password as you wis, remember to Save.
Leon
Post by Leon »
Thank you Matt,
That is exactly what I am trying to do....
I get to the login screen and leave it blank and when I click there is a different message...please see screen shots.
Regards,
Leon.
Image 3.png (37.55 KiB) Viewed 4582 times
Image 4.png (41.44 KiB) Viewed 4582 times
Ok sounds like the same issue as this one?
viewtopic.php?f=61&t=13412
Leon
Post by Leon »
Thank you Matt that is exactly the problem that I am having (as in the link above)
However I have now disabled all add / pop blockers etc. without any joy.
I have tried Safari,Chrome,Opera,Firefox on Mac os and I have tried on iOS....no joy.
I can not think of anything else and have given up :roll:
Regards,
Leon.
pwilman
Post by pwilman »
Leon,
I found that if I clicked on the "local display" version from the nano then I could access the settings and make the changes necessary. I then accessed the "remote display" and the settings I had changed in the local version had come across into the remote version.
Hope this helps you?
Paul
Leon
Post by Leon »
Paul,
Thank you I appreciate your help....that is what I have been doing...BUT I have been logging in remotely to my fantastic MB NANO SD....
Once back I will repeat the whole exercise on my local network :shock:
Maybe that will do the trick.
Regards,
Leon.
pwilman
Post by pwilman »
Leon,
Not tried things remotely. I have been doing all the changes from my local network. Fingers crossed it works for you when you access the Nano locally.
Paul
Leon
Post by Leon »
Thank you,
Problem solved when logging in on local network and NOT remotely.
Regards,
Leon. :D
Next dashboard release will have settings section also to work fine via remote access.
hajovka
Post by hajovka »
On classical Meteobridge running on TPLINK TL-WR703N, I am not able to display Local Dashboard on Weather Network page. I am on local network. I can see it in roll up menu at bottom but no luck when I select it. Meteobridge does not show it on page like other weather networks. Running latest version Meteobridge 3.8 (Dec 27 2018, build 12614), FW 1.4
Local Dashboard is only supported on NanoSD, can't select with MBPro either
