home weather station template with MBPRO
good morning when using a meteobridge pro with home weather station template there is a significant bug in the api output
this was introduced recently and only affects the meteobridge pro output
the phrase CARAMBOLA2 Meteostick is outputted in two words therefore every data point beyond this point is wrongly displayed.
in other products like nano,tplink type it outputs in one word
meteobridge pro output you can see CARAMBOLA2 Meteostick
30/12/2018 00:50:49 -2.2 84.0 -4.5 0.1 0.5 176.0 0.0 0.0 1023.2 176.0 1 m/s C hPa mm 0.0 1023.6 106.0 1004.7 0.0 -- -- -2.2 -0.9 -1.1 20181230000018 -2.2 20181230004808 0.3 20181230000001 0.5 20181230000004 1023.6 20181230000030 1023.1 20181230001401 3.8 12615 0.0 CARAMBOLA2 Meteostick Vantage -- 0.0 -- 176.0 0.0 16.1 20181201143625 -10.6 20181210071251 -3.4 20181229213709 29.4 20180630105834 -13.0 20181110021057 -- 84.0 20181230003814 82.0 20181230000008 -3.8 20181230000018 -4.5 20181230004139 -1.9 83.0 -4.4 -- -- 0.0 0.0 -- -- -- -- -- -- -- 13818 -0.1 20181229131757 -1.9 20181229080326 18.9 20181201143321 -8.7 20181210071251 37.4 20180714160855 -8.7 20181210071251 4.7 20181229063644 15.2 20181227124120 19.5 20180628182545 0.0 106.0 20181201035428 1004.7 20180701195743 -- -- -- -- -- -- -- —- -- -- -- -- -- -- — -5.9 20181229080326 0 -1.5 -- _
nanosd output one word is VOCORE2
30/12/2018 10:51:05 5.6 84.0 3.1 0.4 0.9 46.0 0.0 0.0 1024.0 46.0 1 m/s C hPa mm 0.7 1023.7 98.2 685.2 4.0 20.8 32.0 5.6 5.0 5.7 20181230014150 4.8 20181230063218 4.0 20181230000612 7.6 20181230000645 1024.0 20181230102510 1022.4 20181230055612 3.8 1677 1.8 VOCORE2 Vantage -- 3.0 -- 38.0 0.0 10.3 20181205005923 -4.3 20181227045517 4.9 20181229103320 24.1 20180722180000 -7.1 20180301070000 -- 87.0 20181230064644 83.0 20181230003601 3.4 20181230014150 2.5 20181230090324 5.4 85.0 3.1 20.7 31 0.8 0.7 -- -- -- -- -- -- -- 384467 7.4 20181229000007 5.2 20181229223347 15.3 20181216132253 0.6 20181219171109 33.8 20180723150000 -3.5 20180301230000 9.4 20181229233007 20.6 20181219053233 23.7 20180226230000 4.0 98.2 20181227000014 685.2 20181020230000 -- -- -- -- -- -- -- — -- -- -- -- -- -- -- 2.0 20181229043048 3 5.2 20181229230341 _Partly cloudy with little temperature change.
there is not much i can do on the template side as the whole structure would need to be redone and adjusted to cater for the additional two word phrase so i will suggest
to boris that this data point be removed with just using the format replacing [mbsystem-platform:--] with -- as it is not a critical value merely a reference point.
note error only appearing on meteobridge pro ..brian
Re: home weather station template with MBPRO
this error display output Boris has addressed ..many thanks to boris for the prompt response..turned out to be the station type
Version 3.8
released December 30, 2018
fixes a bug where name of some weather stations is reported in two words instead of one (and by that confuses order of parameters) when doing HomeWeatherStation uploads.
https://wiki.meteobridge.com/wiki/index.php/Forum
30/12/2018 00:50:49 -2.2 84.0 -4.5 0.1 0.5 176.0 0.0 0.0 1023.2 176.0 1 m/s C hPa mm 0.0 1023.6 106.0 1004.7 0.0 -- -- -2.2 -0.9 -1.1 20181230000018 -2.2 20181230004808 0.3 20181230000001 0.5 20181230000004 1023.6 20181230000030 1023.1 20181230001401 3.8 12615 0.0 CARAMBOLA2 Meteostick-Vantage -- 0.0 -- 176.0 0.0 16.1 20181201143625 -10.6 20181210071251 -3.4 20181229213709 29.4 20180630105834 -13.0 20181110021057 -- 84.0 20181230003814 82.0 20181230000008 -3.8 20181230000018 -4.5 20181230004139 -1.9 83.0 -4.4 -- -- 0.0 0.0 -- -- -- -- -- -- -- 13818 -0.1 20181229131757 -1.9 20181229080326 18.9 20181201143321 -8.7 20181210071251 37.4 20180714160855 -8.7 20181210071251 4.7 20181229063644 15.2 20181227124120 19.5 20180628182545 0.0 106.0 20181201035428 1004.7 20180701195743 -- -- -- -- -- -- — -10 -- -- -- -- -- — -10 -5.9 20181229080326 0 -1.5 — _
ConligWX
Post by ConligWX »
Good catch. :wink:
Großvater
Post by Großvater »
many thanks to Boris for this MBpro update,
but after this update the internal Datalogger of the MBpro does'nt work
Best regrads
ralexander5
Post by ralexander5 »
Seeing the same thing here with latest version. Seems to stuck in loop. Log below.
hello boris i had a few emails overnight seems this broke the meteobridge pro .
if that minor change caused the issue just use or replace in the API output [mbsystem-station:--] with --
and revert back
it is not an important data value for the template
brian
I made a mistake in the very latest update, before I was off for two days. bug is fixed now. Sorry for that. :oops:
Please reboot, get newest version by that and it should be fine again.
Großvater
Post by Großvater »
thank you, the MBpro runs again perfect
best regards :D :D
