I bought a Ambient Weather weatherbridge server with Meteohub installed. I plugged in a 16GB thumb drive into the hub. I formated it ext4 before plugging it in. is there a way to access the drive over the network. i saw a reference to that somewhere. don't see where it is mounted in file system.
perhaps i don't know what i'm doing.
https://www.ambientweather.com/amweatherbridge.html
hardware is TP-Link MR3020(UN) Ver 1.9
USB V2 Hub
dmesg:
[ 8.450000] Initializing USB Mass Storage driver...
[ 8.450000] usbcore: registered new interface driver usb-storage
[ 8.460000] USB Mass Storage support registered.
[ 8.660000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 8.810000] hub 1-1:1.0: USB hub found
[ 8.810000] hub 1-1:1.0: 4 ports detected
[ 9.090000] usb 1-1.2: new high-speed USB device number 3 using ehci-platform
[ 9.220000] scsi0 : usb-storage 1-1.2:1.0
[ 9.320000] usb 1-1.3: new full-speed USB device number 4 using ehci-platform
[ 10.450000] scsi 0:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4
[ 10.460000] sd 0:0:0:0: [sda] 31405824 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 10.470000] sd 0:0:0:0: [sda] Write Protect is off
[ 10.470000] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 10.470000] sd 0:0:0:0: [sda] No Caching mode page present
[ 10.480000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.490000] sd 0:0:0:0: [sda] No Caching mode page present
[ 10.490000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.500000] sda: sda1
[ 10.510000] sd 0:0:0:0: [sda] No Caching mode page present
[ 10.510000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.520000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 64.300000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 64.310000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 64.350000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 70.600000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 70.610000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 70.630000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 83.530000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 83.540000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 83.570000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 89.720000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 89.750000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 89.780000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 89.860000] usb 1-1: USB disconnect, device number 2
[ 89.870000] usb 1-1.2: USB disconnect, device number 3
[ 89.900000] usb 1-1.3: USB disconnect, device number 4
[ 89.900000] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[ 89.910000] cp210x 1-1.3:1.0: device disconnected
[ 91.300000] usb 1-1: new high-speed USB device number 5 using ehci-platform
[ 91.450000] hub 1-1:1.0: USB hub found
[ 91.450000] hub 1-1:1.0: 4 ports detected
[ 92.040000] usb 1-1.2: new high-speed USB device number 6 using ehci-platform
[ 92.190000] scsi1 : usb-storage 1-1.2:1.0
[ 92.290000] usb 1-1.3: new full-speed USB device number 7 using ehci-platform
[ 92.420000] cp210x 1-1.3:1.0: cp210x converter detected
[ 92.530000] usb 1-1.3: reset full-speed USB device number 7 using ehci-platform
[ 92.660000] usb 1-1.3: cp210x converter now attached to ttyUSB0
[ 93.490000] scsi 1:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4
[ 93.520000] sd 1:0:0:0: [sda] 31405824 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 93.520000] sd 1:0:0:0: [sda] Write Protect is off
[ 93.530000] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 93.550000] sd 1:0:0:0: [sda] No Caching mode page present
[ 93.550000] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 93.580000] sd 1:0:0:0: [sda] No Caching mode page present
[ 93.580000] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 93.610000] sda: sda1
[ 93.620000] sd 1:0:0:0: [sda] No Caching mode page present
[ 93.620000] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 93.630000] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 720.260000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 720.270000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 720.310000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1322.170000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 1322.180000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 1322.210000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
how to connect usb thumb drive
RottenMutt
- Fresh Boarder
RottenMutt
- Fresh Boarder
Re: how to connect usb thumb drive
can i set up a "service" event to upload my weather data to a ftp server.
how to, please be specific. thank you.
- ConligWX
RottenMutt wrote: Sat Jan 12, 2019 9:43 pm can i set up a "service" event to upload my weather data to a ftp server.
You're best to create a separate thread for other issues so the setup of FTP doesn't get lost in the thread called ""how to connect usb thumb drive"
That said setup of FTP is listed here near the bottom of the page.
https://www.meteobridge.com/wiki/index. ... h_Services
Regards Simon
https://www.conligwx.org/pws
No special format needed and the USB thumb will only be used for storing the application stack downloaded from the Internet. So any small thumb drive will do.
RottenMutt
- Fresh Boarder
so what is the benefit of inserting a thumb drive if it is only used to store the application stack from the internet. when booting can it load the application stack from the usb drive? Also i thought that after inserting the thumb drive it would show in the system tab, but it doesn't.
usb drive has two files, image.tgz and persist.db.tar
i thought i could save weather data to the usb thumb drive.
i attempted to setup a service, my only choices for service are:
i'm stumped...
- email
twitter
http request
ftp upload
sftp upload
camera ftp upload
mysql requests
script execution
sms notification
- periodical
specific time
alarm
i'm stumped...
You are free to create a better solution
RottenMutt
- Fresh Boarder
i'm asking for help.
i wish to ftp weather data to ftp server. can you help me with that?
Have you checked the FTP section of the Push Services?
